查看: 2983|回复: 1
一简单vhdl程序问题,求高手指教
小泡泡 发表于 2010-4-23 11:35:19 | 显示全部楼层 |阅读模式
这是我写的程序,想让它实现单稳态触发功能,但是变异不了,好像陷入了死循环 望高手指教! 谢谢
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity tou is
port(
  -- Input ports
  clk: in  STD_LOGIC;
  intou: in  STD_LOGIC;
  -- Output ports
  otou: out STD_LOGIC
     end entity;
architecture tou_1 of tou is
p1rocess (intou)
variable counter : integer range 0 to 200;
otou<='1';
while (counter<100) loop
  if(clk'event and clk='1') then
  counter :=counter+1;
  end if;
end loop;
counter :=0;
otou<='0';
end process p1;
end tou_1;
fpga_feixiang 发表于 2023-9-8 14:18:50 | 显示全部楼层
6
GMT+8, 2026-5-22 11:12 , Processed in 0.033418 second(s), 24 queries .
