查看: 1778|回复: 1
没有输出block ram !!
applelonger 发表于 2011-4-12 20:40:51 | 显示全部楼层 |阅读模式
大家好
  我用 Block Memory Generator 4.3产生一个 single port block ram.
I set:
Write Width:32
Read Width:32
Write Depth:128
Read Depth:128
Write First
Always Enable
Register Port A Output of Memory Core
Pipeline Stages within Mux :0
仿真结果是douta一直为0,请教高手问题出在了哪里,谢谢!
The module is:
module test5(clka, wea, addra, dina, douta
input clka;
input wea;
input [6:0] addra;
input [31:0] dina;
output [31:0] douta;
Block_RAM BRAM (
  .clka(clk),
  .wea(wea), // Bus [0 : 0]
  .addra(addra), // Bus [6 : 0]
  .dina(dina), // Bus [31 : 0]
  .douta(douta)); // Bus [31 : 0]
module test5_tb;
// Inputs
reg clka;
reg wea;
reg [6:0] addra;
reg [31:0] dina;
// Outputs
wire [31:0] douta;
// Instantiate the Unit Under Test (UUT)
test5 uut (
  .clka(clka),
  .wea(wea),
  .addra(addra),
  .dina(dina),
  .douta(douta)
initial begin
  // Initialize Inputs
  clka = 0;
  wea = 0;
  addra = 0;
  dina = 0;
  // Wait 100 ns for global reset to finish
  #100;
      addra = 23;
  #20;
  addra = 12;
  #10;
  wea = 1;
  dina = 256;
  #20;
  addra = 23;
  dina = 856;
  #30;
  wea = 0;
  #100;
      addra = 23;
  #20;
  addra = 12;
  // Add stimulus here
   always #5 clka = ~clka;
wangxia6112 发表于 2011-6-20 11:33:56 | 显示全部楼层
测试模块中怎么没有$finish。你加上这个试试看。
GMT+8, 2026-5-23 22:10 , Processed in 0.031338 second(s), 20 queries .
