查看: 2370|回复: 1
边沿检测电路
njithjw 发表于 2011-4-12 21:56:29 | 显示全部楼层 |阅读模式
`timescale 1ns/1ns
module cbb_edgedet #
    (parameter EDGE_DETECT="POSEDGE"
    input   SYS_CLK,
    input   RST_N,
    input   SIGNAL_IN,
    output  SIGNAL_EDGE
generate
    if (EDGE_DETECT == "POSEDGE")
    begin: POSE_EDGE
        reg     SIGNAL_IN_DLY1;
        reg     SIGNAL_IN_DLY2;
        reg     SIGNAL_IN_DLY3;
        reg     SIGNAL_RISE;
        always @ (posedge SYS_CLK or negedge RST_N)
            if (RST_N == 1'B0)
                SIGNAL_IN_DLY1 <= 1'B0;
                SIGNAL_IN_DLY2 <= 1'B0;
                SIGNAL_IN_DLY3 <= 1'B0;
                SIGNAL_IN_DLY1 <= SIGNAL_IN;
                SIGNAL_IN_DLY2 <= SIGNAL_IN_DLY1;
                SIGNAL_IN_DLY3 <= SIGNAL_IN_DLY2;
            if (RST_N == 1'B0)
                SIGNAL_RISE <= 1'B0;
                SIGNAL_RISE <= ~SIGNAL_IN_DLY3 && SIGNAL_IN_DLY2;
        assign SIGNAL_EDGE = SIGNAL_RISE;
    else if (EDGE_DETECT == "NEGEDGE")
    begin: NEGE_EDGE
        reg     SIGNAL_IN_DLY1;
        reg     SIGNAL_IN_DLY2;
        reg     SIGNAL_IN_DLY3;
        reg     SIGNAL_FALL;
            if (RST_N == 1'B0)
            if (RST_N == 1'B0)
                SIGNAL_FALL <= 1'B0;
                SIGNAL_FALL <= SIGNAL_IN_DLY3 && (~SIGNAL_IN_DLY2);
        assign SIGNAL_EDGE = SIGNAL_FALL;
    else if (EDGE_DETECT == "DUALDGE")
    begin: DUAL_EDGE
        reg     SIGNAL_IN_DLY1;
        reg     SIGNAL_IN_DLY2;
        reg     SIGNAL_IN_DLY3;
        reg     SIGNAL_RISE_FALL;
            if (RST_N == 1'B0)
            if (RST_N == 1'B0)
                SIGNAL_RISE_FALL <= 1'B0;
                SIGNAL_RISE_FALL <= SIGNAL_IN_DLY3 ^ SIGNAL_IN_DLY2;
        assign SIGNAL_EDGE = SIGNAL_RISE_FALL;
endgenerate
哦十全_至芯学员 发表于 2011-4-17 23:08:17 | 显示全部楼层
顶一个先……
GMT+8, 2026-5-24 01:10 , Processed in 0.031633 second(s), 20 queries .
