查看: 2243|回复: 2
quartus 编写的RAM读写出现错误
huangying 发表于 2011-4-13 11:17:34 | 显示全部楼层 |阅读模式
Error (10200): Verilog HDL Conditional Statement error at MC_v4.v(125): cannot match all operands in the condition expression to corresponding edges in the enclosing Always Construct's Event Control
Error (10200): Verilog HDL Conditional Statement error at MC_v4.v(127): cannot match all operands in the condition expression to corresponding edges in the enclosing Always Construct's Event Control
Error: Can't elaborate top-level user hierarchy
我的程序是利用quartus自动生成的单口ram,还有锁相环pll,总线仲裁是9054的,那本分没错。主要是ram读写的问题。自己给了一个ram 输入数据。
程序如下
module quartus_ram(//时钟和复位
                                clk_in,        rst_n,
                                //总线握手
                                hold,        holda,        blast_n,        ads_n ,
                                ready_n,bterm_n,ccs_n        ,
        //地址数据读写信号
                                write_read,        address_bus,        data_bus
//clock
input        rst_n ;
input         clk_in ;
wire         clk_glable;//全局时钟
wire         clk_glable_test;
clk_pll clk_gen_0(        .inclk0(clk_in),
                                        .c0(clk_glable),
                                        .c1(clk_glable_test));
//bus_arbitrate
supply1        vcc;
output         bterm_n;
output         ccs_n;
assign bterm_n = vcc ;
assign ccs_n = vcc ;
input hold ;
input blast_n ;
input ads_n;
output holda ;
output ready_n;
bus_arbitrate  arbitrate(         .hold(hold),
                                                        .blast_n (blast_n),
                                                        .ads_n (ads_n),
                                                        .gclk (clk_glable),
                                                        .rst_n (rst_n),
                                                        .holda(holda) ,
                                                        .ready_n(ready_n)
//数据总线  1 write 0 read
input write_read ;
inout [31:0]data_bus ;
wire  [31:0]data_local_in ;
reg   [31:0]data_local_out ;
assign data_local_in = data_bus ;
assign data_bus =  (~write_read) ? data_local_out : 32'bzzzz_zzzz_zzzz_zzzz_zzzz_zzzz_zzzz_zzzz ;
input [15:2]address_bus;
reg [31:0]enable ;
always @ (posedge clk_glable or negedge rst_n)        begin
                if (rst_n == 0 )     begin      //复位
                        //channel_0_counter        <= 0;
//                        channel_1_counter        <= 0;
                        //dir                                 <= 32'b1111_1111_1111_1111_1111_1111_1111_1111;
                        enable                                  <= 32'b0000_0000_0000_0000_0000_0000_0000_0000;
                        data_local_out                 <= 32'b0000_0000_0000_0000_0000_0000_0000_0000;
                        //channel_0_send_p        <= 800_000;
                        //to_zero_bit_buf         <= 32'b0000_0000_0000_0000_0000_0000_0000_0000;
                else if(ready_n == 1'b0 )        begin //数据和地址都已经准备好 1 write 0 read
                                if ( write_read == 1'b1 )
                                        case (address_bus)
                                                14'b00000000010001 : enable                         <= data_local_in ;
                                                default :        ;
                                        endcase
                                else if( write_read == 1'b0)                        //读
                                        case (address_bus)
                                        //分频数据反馈
                                                14'b00000000010010 : data_local_out <= dataout;
                                                14'b00000000000101 : data_local_out <= 5;
                                                default                    : data_local_out <= 32'b0000_0000_0000_0000_0000_0000_0000_0011;
                                        endcase
//通道定时发生
wire [7:0]addr;
reg[7:0]addr_buf;
reg[31:0]datain_buf;
reg[31:0]datain;
reg wr;
wire[31:0]dataout_buf;
reg[7:0]wr_addr_buf;
reg[7:0]rd_addr_buf;
reg[31:0]dataout;
assign addr=addr_buf;
ram ram_one(
        .address(addr),
        .clock(clk_glable),
        .data(datain),
        .wren(wr),
        .q(dataout_buf));
always@(posedge clk_glable or negedge rst_n)
  if(rst_n==0)
  datain_buf<=32'b0000_0000_0000_0000_0000_0000_0000_0000;
  wr<=1;
   if(datain_buf>=32'b0000_0000_0000_0000_0000_0000_1100_1000)
    wr<=0;
    datain_buf<=datain_buf+32'b0000_0000_0000_0000_0000_0000_0000_0001;
    wr<=1;
if(wr==1) addr_buf<=wr_addr_buf;
else if(wr==0) addr_buf<=rd_addr_buf;
addr_buf<=8'b0000_0000;
if(rst_n==0)
  wr_addr_buf<=8'b0000_0000;
  rd_addr_buf<=8'b0000_0000;
  dataout<=32'b0000_0000_0000_0000_0000_0000_0000_0000;
  datain<=32'b0000_0000_0000_0000_0000_0000_0000_0000;
else if(wr==1)
  wr_addr_buf<=wr_addr_buf+8'b0000_0001;
  datain<=datain_buf;
else if(wr==0)
rd_addr_buf<=rd_addr_buf+8'b0000_0001;
  dataout<=dataout_buf;
 楼主| huangying 发表于 2011-4-13 14:44:54 | 显示全部楼层
大家帮帮忙,我刚开始学
哦十全_至芯学员 发表于 2011-4-17 23:03:18 | 显示全部楼层
你可以调用个ip核。
GMT+8, 2026-5-24 01:10 , Processed in 0.032628 second(s), 21 queries .
