查看: 1602|回复: 0
ISE8.2中遇到问题,求解答!!!
Tomato 发表于 2011-4-19 18:53:29 | 显示全部楼层 |阅读模式
我是一个初学者,第一次按照课本进行操作,当进行到测试平台的编写这一步时,出现了问题进行不下去了,我建的测试文件名为test_one4two1这是自动生成的测试模块代码
// Verilog Test Fixture Template
  `timescale 1 ns / 1 ps
  module TEST_gate;
          reg <signal1>;
          reg [2:0] <signal2>;
          wire [3:0] <signal3>;
          wire <signal4>;
          <module_name> <instance_name> (
                  <port1>,
                  <port2>
          integer <name1>;
          integer <name2>;
   // The following code initializes the Global Set Reset (GSR) and Global Three-State (GTS) nets
   // Refer to the Synthesis and Simulation Design Guide for more information on this process
   reg GSR;
   assign glbl.GSR = GSR;
   reg GTS;
   assign glbl.GTS = GTS;
   initial begin
      GSR = 1;
      GTS = 0; // GTS is not activated by default
      #100; // GSR is set for 100 ns
      GSR = 0;
  // Initialize Inputs
      `ifdef auto_init
          initial begin
      `endif
这是WARING和ERROR
WARNING: could not create F:/FPGA store/ISE/one4two/test_one4two1.v. Defaulting to boilerplate.
ERRORortability:90 - Command line error: Unexpected argument[14]Usage: vhdtdtfi {-lib <libname> {<vhdfile>}} [-lang vhdl|verilog] [-module
求高人解答!!我的QQ是904122918,如能在线帮忙,感激不尽~~
GMT+8, 2026-5-24 01:26 , Processed in 0.037083 second(s), 21 queries .
