查看: 2814|回复: 5
我是初学者,我在网上下载了一个FPGA工程,有一处错误请哪位高手指点一下
fumu 发表于 2011-4-22 15:33:52 | 显示全部楼层 |阅读模式
/*   CSL configuration is no longer supported.    */
/*   Your CSL configuration has been saved here as part  */
/*   of the process of converting cdb to tcf.    */
/* INPUT mpeg2_encoder.cdb */
[color=Lime]
/*  Include Header File */
#include "mpeg2_encodercfg_csl.h"
#error "Please read the comment below to finish updating your project"
* The following steps are required to use this file:
* 1.  Modify any source files that use these structures to
*     `#include <mpeg2_encodercfg_csl.h>`.  These structure definitions were
*     previously contained in <mpeg2_encodercfg.h>.
* 2.  Call `CSL_init()` and `cslCfgInit()` from your application's main()
*     function.  This is necessary to initialize CSL and the assorted
*     CSL handles.  These functions were previously called by BIOS internally.
* 3.  Remove the #error line above.
* 4.  Update your linker options to include the CSL library for the device
*     that you are using. This library name was listed in the original
*     generated mpeg2_encodercfg.cmd file (e.g., "-lcsl6416.lib").
* 5.  If you are using the 54x or 55x, you will need to create an additional
*     linker .cmd file that includes the generated mpeg2_encodercfg.cmd file
*     and adds section placement for the '.csldata' section.
* See the DSP/BIOS Setup Guide for more information.
#pragma CODE_SECTION(cslCfgInit,".text:cslCfgInit")
/*  Config Structures */
/* EMIFA_Config emifaCfg0
* comment                                                 <add comments here>
* External HOLD disable (NOHOLD)                          Enable Hold
* CLKOUT4 Enable (CLK4EN)                                 Enabled to clock
* CLKOUT6 Enable (CLK6EN)                                 Enabled to clock
* ECLKOUT1 Enable (EK1EN)                                 Enabled to clock
* ECLKOUT2 Enable (EK2EN)                                 Enabled to clock
* ECLKOUT1 High-Z Control (EK1HZ)                         High-Z during hold
* ECLKOUT2 High-Z Control (EK2HZ)                         Clock during hold
* ECLKOUT2 Rate (EK2RATE)                                 1/2x EMIF input clock
* Bus Request Mode                                        access/refresh pending or in progress
* Memory Type (MTYPE)                                     64-bit SDRAM
* Read Strobe Width                                       0x3F
* Read Setup Width                                        0xF
* Read Hold Width                                         0x3
* Write Strobe Width                                      0x3F
* Write Setup Width                                       0xF
* Write Hold Width (WRHLD-WRHLDMSB)                       0x3
* Turn around time (TA)                                   0x3
* Memory Type (MTYPE)                                     16-bit async. interf.
* Read Strobe Width                                       0xE
* Read Setup Width                                        0x2
* Read Hold Width                                         0x1
* Write Strobe Width                                      0xE
* Write Setup Width                                       0x7
* Write Hold Width (WRHLD - WHLDMSB)                      0x2
* Turn around time (TA)                                   0x2
* Write Hold Width                                        0x2
* Memory Type (MTYPE)                                       8-bit async. interf.
* Sync. interf. data read latency (SYNCRL)                2 cycles
* Sync. interf. data write latency (SYNCWL)               0 cycle
* CE Extension Register (CEEXT)                           Inactive
* Read Enable Enable (RENEN)                              ADS Mode
* Synchronization Clock (SNCCLK)                          Sync. to ECLKOUT1
* TRC = trc/(eclkout1 period-1) (TRC)                     0x5
* TRP = trp/(eclkout1 period-1) (TRP)                     0x1
* TRCD = trcd/(eclkout1 period-1) (TRCD)                  0x1
* Initialization of all SDRAMs (INIT)                     Initialize
* SDRAM Refresh Enable (RFEN)                             Enable
* Column Size (SDCSZ)                                      8 addresses
* Row Size (SDRSZ)                                        12 addresses
* Bank Size (SDBSZ)                                       Four banks
* Self-refresh mode(SLFRFR)                               Disable
* Refresh Period (ECLKOU1 cycles)                         0x81B
* Extra Refreshes Ctrl. (XRFR)                            0x1
* CAS Latency (TCL)                                       0x3
* tras = TRAS + 1 (ECLKOU1 cyc.)                          0x7
* trrd = TRRD (2 or 3 ECLKOU1 cyc.)                       0x2
* twr  = TWR + 1 (ECLKOU1 cyc.)                           0x3
* thzp = THZP + 1 (ECLKOU1 cyc.)                          0x3
* READ-To-READ (ECLKOU1 cyc.)                             0x2
* READ-To-DEAC/DEAB (ECLKOU1 cyc.)                        0x4
* READ-To-WRITE (ECLKOU1 cyc.)                            0x3
* READ-To-WRITE with Interrupt (BEx cyc.)                 0x4
* WRITE-To-WRITE (ECLKOU1 cyc.)                           0x2
* WRITE-To-DEAC/DEAB (ECLKOU1 cyc.)                       0x4
* WRITE-To-READ (# of ECLKOU1 cyc.)                       0x2
* Global Control Reg. (GBLCTL)                            0x0005207C
* CE0 Space Control Reg. (CECTL0)                         0xFFFFFFD3
* CE1 Space Control Reg. (CECTL1)                         0x73A28E11
* CE2 Space Control Reg. (CECTL2)                         0x73A28E11
* CE3 Space Control Reg. (CECTL3)                         0x73A28E01
* SDRAM Control Reg.(SDCTL)                               0x57115000
* SDRAM Timing Reg.(SDTIM)                                0x005DC81B
* SDRAM Extended Reg.(SDEXT)                              0x001FAF4D
* CE0 Space Secondary Control Reg. (CESEC0)               0x00000002
* CE1 Space Secondary Control Reg. (CESEC1)               0x00000002
* CE2 Space Secondary Control Reg. (CESEC2)               0x00000002
* CE3 Space Secondary Control Reg. (CESEC3)               0x00000002
EMIFA_Config emifaCfg0 = {
    0x0005207C,        /*  Global Control Reg. (GBLCTL)   */
    0xFFFFFFD3,        /*  CE0 Space Control Reg. (CECTL0)   */
    0x73A28E11,        /*  CE1 Space Control Reg. (CECTL1)   */
    0x73A28E11,        /*  CE2 Space Control Reg. (CECTL2)   */
    0x73A28E01,        /*  CE3 Space Control Reg. (CECTL3)   */
    0x57115000,        /*  SDRAM Control Reg.(SDCTL)   */
    0x005DC81B,        /*  SDRAM Timing Reg.(SDTIM)   */
    0x001FAF4D,        /*  SDRAM Extended Reg.(SDEXT)   */
    0x00000002,        /*  CE0 Space Secondary Control Reg. (CESEC0)  */
    0x00000002,        /*  CE1 Space Secondary Control Reg. (CESEC1)  */
    0x00000002,        /*  CE2 Space Secondary Control Reg. (CESEC2)  */
    0x00000002         /*  CE3 Space Secondary Control Reg. (CESEC3)  */
/*  Handles  */
*  ======== cslCfgInit() ========
void cslCfgInit()
错误提示:
[mpeg2_encodercfg_csl.c] "D:\CCS3\C6000\cgtools\bin\cl6x" -g -q -o3 -fr"D:/CCS3/MyProjects/OSDmpeg4_Lyang_08_0523/obj/" -i"D:/CCS3/MyProjects/OSDmpeg4_Lyang_08_0523/include" -d"_DEBUG" -d"_PAL" -d"CHIP_DM642" -d"C6000" -mt -ml3 -mv6400 -@"Debug.lkf" "mpeg2_encodercfg_csl.c"
"mpeg2_encodercfg_csl.c", line 10: fatal error: #error "Please read the comment below to finish updating your project"
1 fatal error detected in the compilation of "mpeg2_encodercfg_csl.c".
Compilation terminated.
安圣基 发表于 2011-4-24 11:48:03 | 显示全部楼层
你确定你这是工程 我是看不懂了 连个模块都没有
这是什么语言编的啊
zgtianlei 发表于 2011-4-25 19:40:22 | 显示全部楼层
nios工程?我不懂~~
 楼主| fumu 发表于 2011-4-25 22:22:22 | 显示全部楼层
C语言写的,这是在DM642上移植MPEG-4源代码中的一个文件"mpeg2_encodercfg_csl.c",其他编译都通过了,就这有一个error
 楼主| fumu 发表于 2011-4-26 08:15:11 | 显示全部楼层
不好意思   弄错了
xuzixin 发表于 2011-4-27 20:15:36 | 显示全部楼层
楼主,应该发错了       看不懂~
GMT+8, 2026-5-23 23:49 , Processed in 0.040377 second(s), 23 queries .
