查看: 3413|回复: 3
二进制转BCD码的VHDL程序
小泡泡 发表于 2010-4-23 12:21:07 | 显示全部楼层 |阅读模式
把一个二进制数转换成7个4位BCD码(二进制数大小合适),怎样编写VHDL程序?
比如把“1010 1010”(二进制)转换成“0000 0000 0000 0000 0001 0111 0000”(BCD)
 楼主| 小泡泡 发表于 2010-4-23 12:21:21 | 显示全部楼层
回复 1# 小泡泡
    仅供参考
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity B_BCD is
port(clk:in std_logic;
   din:in std_logic_vector(26 downto 0);
      y0,y1,y2,y3,y4,y5,y6,y7ut std_logic_vector(3 downto 0));
end B_BCD;
architecture behav of B_BCD is
type state is (s0,s1,s2);
signal present_state:state;
signal mid_in:std_logic_vector(26 downto 0);
signal d0,d1,d2,d3,d4,d5,d6,d7:std_logic_vector(3 downto 0);
process(clk)is
  if clk‘event and clk=‘1‘ then
   mid_in<=din;
   present_state<=s0;
   case (present_state) is
    when s0=>
     d0<=“0000“;d1<=“0000“;d2<=“0000“;d3<=“0000“;d4<=“0000“;d5<=“0000“;d6<=“0000“;d7<=“0000“;
     present_state<=s1;
    when s1=>
     if mid_in>=“100110001001011010000000“ then mid_in<=mid_in-“100110001001011010000000“;
  d7<=d7+1;
  present_state<=s1;
   elsif mid_in>=“000011110100001001000000“ then  mid_in<=mid_in-“000011110100001001000000“;
  d6<=d6+1;
present_state<=s1;
  elsif mid_in>=“000000011000011010100000“ then  mid_in<=mid_in-“000000011000011010100000“;
   d5<=d5+1;
   present_state<=s1;
  elsif mid_in>=“000000000010011100010000“ then  mid_in<=mid_in-“000000000010011100010000“;
  d4<=d4+1;
  present_state<=s1;
   elsif mid_in>=“000000000000001111101000“ then  mid_in<=mid_in-“000000000000001111101000“;
   d3<=d3+1;
  present_state<=s1;
   elsif mid_in>=“000000000000000001100100“ then  mid_in<=mid_in-“000000000000000001100100“;
   d2<=d2+1;
  present_state<=s1;
   elsif mid_in>=“000000000000000000001010“ then  mid_in<=mid_in-“000000000000000000001010“;
   d1<=d1+1;
  present_state<=s1;
  elsif mid_in>=“000000000000000000000001“ then
m
 楼主| 小泡泡 发表于 2010-4-26 20:49:59 | 显示全部楼层
好像没写完
weibode01 发表于 2010-11-9 11:01:38 | 显示全部楼层
用VERILOG好像没那么长吧
GMT+8, 2026-5-24 04:11 , Processed in 0.033659 second(s), 20 queries .
