查看: 1298|回复: 0
急急急 求高手解答
liwc1991 发表于 2011-4-28 09:30:28 | 显示全部楼层 |阅读模式
我将process(a) 改成process(a,b) 在波形图里设置了b恒为0,为什么波形图会发生如此大的变化。b不变不是没影响吗?求解答啊 这个困扰了我2天的问题 以下为源程序,没改之前波形相当正常
Library IEEE;
Use IEEE.STD_LOGIC_1164.ALL;
entity shouhj is
port
  -- Input ports
  a,b         : in  std_logic;
  -- Output ports
  x,y,z       : out std_logic
end shouhj;
architecture arch of shouhj is
    TYPE all_state IS(s0,s1,s2,s3,s4);
    SIGNAL state:all_state;
-- Declarations (optional)
    p1ROCESS(a)
    BEGIN
       IF (  a='1' ) THEN
           CASE state IS
              WHEN s0=> state<=s1;
              WHEN s1=> state<=s2;
              WHEN s2=> state<=s3;
              WHEN s3=> state<=s4;
              WHEN s4=> state<=s0;
              WHEN OTHERS=> NULL;
           end case;
       end if;
       end process p1;
     p2ROCESS(state)
           CASE state IS
              WHEN s0=> x<='0';y<='0';z<='0';
              WHEN s1=> x<='1';y<='1';z<='0';
              WHEN s2=> x<='1';y<='0';z<='0';
              WHEN s3=> x<='1';y<='1';z<='0';
              WHEN s4=> x<='1';y<='1';z<='1';
              WHEN OTHERS=> NULL;
           end case;
    end process p2;
end arch;
GMT+8, 2026-5-24 00:39 , Processed in 0.031878 second(s), 20 queries .
