查看: 1198|回复: 1
发送模块各个子模块
小舍YZ 发表于 2017-9-15 14:28:32 | 显示全部楼层 |阅读模式
发送模块各个子模块
REBEGIN程序
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY REBEGIN IS
        PORT
                A,B                : IN        STD_LOGIC;
                C                : OUT        STD_LOGIC
END REBEGIN;
ARCHITECTURE A OF REBEGIN IS
        SIGNAL TEMP        : STD_LOGIC;
BEGIN
        PROCESS (A,B)
        BEGIN
                TEMP<=B;
                IF(TEMP='1')THEN
                        C<='0';
                ELSE
                        C<=A;
                END IF;
        END PROCESS;
END A;
REBEGIN_4程序
LIBRARY IEEE;
ENTITY REBEGIN_4 IS
        PORT(
                A,B                        : IN        STD_LOGIC;
                EN                        : OUT        STD_LOGIC
END REBEGIN_4;
ARCHITECTURE A OF REBEGIN_4 IS
BEGIN
        PROCESS (A,B)
        BEGIN
                TEMP<=A OR B;
                IF(TEMP='1')THEN
                        EN<='1';
                ELSE
                        EN<='0';
                END IF;
        END PROCESS;
END A;
EN程序
LIBRARY IEEE;
ENTITY EN IS
        PORT
                EN,A                : IN        STD_LOGIC;
                B                        : OUT        STD_LOGIC
END EN;
ARCHITECTURE A OF EN IS
BEGIN
        PROCESS (EN)
        BEGIN
        TEMP<=EN;
        IF(TEMP='1')THEN
                B<=A;
        ELSE
                B<='0';
        END IF;
        END PROCESS;
END A;
FENPIN程序
LIBRARY IEEE;
ENTITY FENPIN IS
        PORT
                CLK,EN        : IN        STD_LOGIC;
                CLKOUT        : OUT        STD_LOGIC
END FENPIN;
ARCHITECTURE A OF FENPIN IS
        SIGNAL        NUMBER                        : INTEGER RANGE 0 TO 998;
BEGIN
        PROCESS (EN,CLK)
        BEGIN
        IF(CLK 'EVENT AND CLK='1')THEN
        IF(EN='1')THEN
                CLKOUT<='1';
                NUMBER<=NUMBER+1;
                IF(NUMBER>=1)THEN
                        IF(NUMBER=998)THEN
                                NUMBER<=0;
                        END IF;
                        CLKOUT<='0';
                END IF;
        END IF;
        END IF;
        END PROCESS;
END A;
TRANSMIT程序
LIBRARY IEEE;
ENTITY TRANSMIT IS
        PORT
                EN,CLK        : IN        STD_LOGIC;
END TRANSMIT;
ARCHITECTURE A OF TRANSMIT IS
BEGIN
        PROCESS (EN,CLK)
        BEGIN
        IF(EN='0')THEN
                CLKOUT<='0';
        ELSE
                        CLKOUT<='1';
                        NUMBER<=NUMBER+1;
                        IF(NUMBER>=1)THEN
                                IF(NUMBER=998)THEN
                                        NUMBER<=0;
                                END IF;
                                CLKOUT<='0';
                        END IF;
                END IF;
        END IF;
        END PROCESS;
END A;
ENCODE程序
LIBRARY IEEE;
ENTITY ENCODE IS
        PORT
                EN,CLK,DATA_IN        : IN        STD_LOGIC;
                ZO                                : OUT        STD_LOGIC
END ENCODE;
ARCHITECTURE A OF ENCODE IS
        SIGNAL        COUNT        : INTEGER RANGE 0 TO 3;
        SIGNAL  Z                : STD_LOGIC;
BEGIN
        PROCESS (CLK)
        BEGIN
        IF(EN='0')THEN
                ZO<='0';
        ELSE
                IF(DATA_IN='0')THEN
                        ZO<='0';
                ELSE
                        COUNT<=COUNT+1;
                        IF(COUNT=3)THEN
                                COUNT<=0;
                        END IF;
                        CASE COUNT IS
                                WHEN 0=>Z<='1';
                                WHEN 1=>Z<='0';
                                WHEN 2=>Z<='1';
                                WHEN 3=>Z<='0';
                        END CASE;
                        ZO<=Z;
                END IF;
        END IF;
        END IF;
        END PROCESS;
END A;
MUX2TO1程序
LIBRARY IEEE;
ENTITY MUX2TO1 IS
        PORT
                A,B,SEL                        : IN        STD_LOGIC;
                C                                : OUT   STD_LOGIC
END MUX2TO1;
ARCHITECTURE A OF MUX2TO1 IS
BEGIN
        PROCESS (A,B,SEL)
        BEGIN
                TEMP<=SEL;
                IF(TEMP='1')THEN
                        C<=A;
                ELSE
                        C<=B;
                END IF;
        END PROCESS;
END A;
fpga_feixiang 发表于 2017-9-15 14:56:38 | 显示全部楼层
还是VHDL的,
GMT+8, 2026-5-23 06:08 , Processed in 0.032477 second(s), 21 queries .
