查看: 22989|回复: 0
FPGA Programmability and Performance Empower Machine Vision and Surveillance
4798345 发表于 2017-9-28 09:09:36 | 显示全部楼层 |阅读模式
Cameras and other equipment used in Surveillance and Machine Vision perform a variety of different tasks,
ranging from Image Signal Processing (ISP), Video Transport and Video Format Conversion to Video Compression
and Analytics.
Video Processing – Today versus Tomorrow
Te video processing chain, starting from a CMOS or CCD image sensor and ending at a display, storage or video
transport medium consists of several stages such as sensor interfacing, image signal processing, image compression,
video format conversion (transcoding), transport and storage. Traditional video processing still largely consists of
discrete devices such as Digital Signal Processors (DSP) for each of these functions. Tere are Application Specifc
Standard Products (ASSPs) available that combine two or more of the above
functions; however once an ASSP has been fabricated it cannot be altered, creating
a challenge for video system designers. Tis challenge is due to several reasons:
rapid changes in sensor technologies that require new ways of interfacing with
sensors, the introduction of High Dynamic Range (HDR) requirement into the
image signal processing pipelines to enable cameras to see equally well in mixed
light and dark areas of a scene, improvement in the efciency of compression
algorithms and the emerging need to support Video Content Analytics (VCA).
Programmable devices like the FPGA offer system designers the flexibility to respond
to these challenges by empowering them with the ability to change the behavior of
the hardware used to implement these functions. Since FPGAs are reprogrammable,
they can be used to implement multiple behaviors within the same device. Entire
cameras, surveillance systems and machine vision systems can be implemented in
a single device, thus reducing cost, power consumption, and board space, while
improving the reliability of the system due to fewer components. Also, due to their
parallel computing nature, FPGAs tend to provide accelerated performance over DSP
for many of the functionalities required in Video Surveillance and Machine Vision.
FPGAs Make it Easy to Support New Image Sensor Interfaces
CMOS and CCD camera image sensors convert light (visible, infrared, etc.) into electrical signals. It is common
for sensor manufacturers to use different electrical interfaces to output pixel information from the sensors. Tese
interfaces can vary greatly between devices even from the same sensor manufacturer. Tis ofen poses a problem
for camera manufacturers implementing ISP pipelines in ASSPs which are usually constrained in their ability to
interface with one or two sensor interface schemes. FPGAs, on the other hand, being fully programmable, do not
have such constraints, and can easily be reprogrammed to accommodate different – even totally new – camera
sensor interfaces. For example, of late, a large number of sensor manufacturers have made a transition from
parallel to serial image sensor interfaces to accommodate higher data output rate from high megapixel sensors.
Sensor interfaces implemented in FPGA enable camera manufacturers to upgrade to newer, improved sensors
as and when they become available without having to redesign their camera board with a different ASSP.Altera Cyclone® V SoC showing Implementation of ISP Pipeline and Video Analytics
FPGAs Deliver High-performance Image Signal Processing at Signifcantly Reduced Cost
Image sensor resolutions have been steadily increasing and are trending from 1 Megapixel to 5 Megapixels and beyond. Data out
of the sensors may have resolution of 20 bits per pixel or more. Full HD (1920x 1080) display resolution, refreshed at 60 frames
per second is becoming standard. High (or Wide) Dynamic Range (HDR/WDR) is required for many surveillance applications,
especially ones that will interface to video analytics. HDR/WDR is ofen implemented by sensor manufacturers with schemes
that require multiple exposures in the sensor to create one output frame (e.g. a particular Aptina HDR sensor internally uses 3
exposures per frame). In such a case, in terms of frames that must be processed to output a display frame rate of 60 fps, the
image signal processing pipeline actually needs to process 60 x 3 = 180 frames per second. Tis combination leads to a very
large quantity of data that must be processed in near-real-time so as to avoid latency (delay) between the physical scene and
the processed image. For example, at 20 bits per pixel we have:
(1920 x 1080) pixels x 20 bits/pixel x 180 frames/sec = > 7 Gbits/sec of data
Traditional Digital Signal Processing requires a very high performance DSP to process 1080p60 HDR, with high price points.
Te same image signal processing performance can be achieved in an FPGA, such as Altera MAX® 10 or Cyclone® IV, at a fraction
of the cost. Depending on the implementation, a 1080p60 HDR pipeline implemented in an FPGA can be less than two-thirds
to less than half the cost of equivalent implementation in DSP, for the same image quality.
Programmability of the FPGA fabric offers further flexibility by enabling camera manufacturers to make changes to the ISP
blocks to add or subtract functionality and tweak quality and performance, giving them the ability to implement a wide range
of camera product line on a relatively small set of boards.
FPGAs Enable Flexible High Efciency Video Compression
With the trend towards IP (Internet Protocol) cameras, Ethernet is being adopted as the interface of choice in video transport,
creating substantial savings over coaxial cable costs. Video over Ethernet does require H.264/H.265 type of compression,
which in the past required signifcantly large FPGAs – of the order of 70KLE (Logic Elements). However, newer high-efciency
compression algorithms are able to implement video compression in half that LE count. Tis, combined with a lower total
integrated cost compared to DSPs, makes FPGAs a solid choice for video compression. Furthermore, it is a simple matter to
program one or more Ethernet MACs (Media Access Controller) within the FPGA, to drive video over Ethernet straight out
of the FPGA with the addition of only an external PHY.
Programmability of the FPGA offers additional flexibility by enabling camera manufacturers to customize the compression block
to implement only the compression profle required for the particular application, or even to reprogram the FPGA with a different
compression profle when needed. Unlike ASSPs that may offer a choice of a few compression profles, there is no real limit other
than the size of the chosen FPGA for various different compression profles that may be programmed.
Frame
Buer
Menory
Video
Out
Hard Processor System (HPS)
Video Content Analytics Algorithms
for Machine Vision and Surveillance
Dual Core ARM® A9
Nios®-II
HD-SDI
USB 3.0
GigEVision
CameraLink HS
CoaXPress
AF Motor
FPGA FABRIC AXI
I/F
Auto
Focus
De-Bayer
Auto
Exposure
Color
Correction
Matrix
Sensor
Interface
Color
Space
Conversion
HDR
Block
Gamma
Correction
H.264
Compression
Auto
White
Balance
2D
Defective
Pixel
Correction
M E T A D A T AAltera Corporation
101 Innovation Drive
San Jose, CA 95134
USA
www.altera.com
Altera European Headquarters
Holmers Farm Way
High Wycombe
Buckinghamshire
HP12 4XF
United Kingdom
Telephone: (44) 1494 602000
Altera Japan Ltd.
Shinjuku i-Land Tower 32F
6-5-1, Nishi-Shinjuku
Shinjuku-ku, Tokyo 163-1332
Japan
Telephone: (81) 3 3340 9480
www.altera.co.jp
Altera International Ltd.
Unit 11- 18, 9/F
Millennium City 1, Tower 1
388 Kwun Tong Road
Kwun Tong
Kowloon, Hong Kong
Telephone: (852) 2 945 7000
www.altera.com.cn
Copyright © 2014 Altera Corporation. All rights reserved. Altera, the stylized Altera logo, speciἀc device designations, and all other words and logos that are identifed as trademarks and/or service marks
are, unless noted otherwise, the trademarks and service marks of Altera Corporation in the U.S. and other countries. All other product or service names are the property of their respective holders. Altera
products are protected under numerous U.S. and foreign patents and pending applications, mask work rights, and copyrights. Altera warrants performance of its semiconductor products to current
specifcations in accordance with Altera’s standard warranty, but reserves the right to make changes to any products and services at any time without notice. Altera assumes no responsibility or liability
arising out of the application or use of any information, product, or service described herein except as expressly agreed to in writing by Altera. Altera customers are advised to obtain the latest version of
device specifcations before relying on any published information and before placing orders for products or services. August 2014 SS-1067
FPGAs Provide the Performance and Flexibility for Real-Time Transcoding
Video transport protocol translation is ofen required between the source and destination equipment. A very signifcant amount of
video data needs to be reformatted while converting (transcoding) from one transport protocol to another in near-real-time, such
as between CameraLink, GigEVision, DVI, SDI, HD-SDI, 3G-SDI, USB3.0 and CoaXPress. Tis is more cost effective to accomplish
in a parallel processing device like an FPGA, and can ofen be integrated within the camera on the same FPGA being used for ISP.
Programmability of the FPGA also offers camera manufacturers the ability to reprogram different transport interfaces onto the same
board as needed, optimizing the total number of boards to support a broad product line.
High speed serial video transport protocols like HD-SDI (1.485Gb/s) are evolving to 3G-SDI (2.97Gb/s) and CoaXPress (6.25 Gbps)
and are able to leverage the already built in transceivers in certain classes of FPGAs for integration of image signal processing, HDR
and high speed video transport on a single chip.
SoC FPGAs Provide the Processing Power to Implement Video Content Analysis
Video Content Analytics (VCA) is a compute-intensive application that involves analyzing real-time changes in macro image blocks
like people, objects, license plates, virtual trip wires, etc. in a video stream. It requires the blocks to be identifed, their behavior
tracked and decisions to be made with regard to either their content (e.g. reading a number plate) or intent as threatening or
non-threatening (e.g. object lef behind- in a crowded place which may contain explosives). Tey are also used for applications like
people counting that may be used for statistical purposes such as recording trade show attendance or crowd control. In order for
VCA to be effective in its ultimate goals of preserving safety and security, analysis must happen in real-time. Tis requires both the
deployment of high computing power as well as low latency between the occurrence of events and their analyses.
VCA is an area where the combined power of FPGA fabric and Hard Processor System (HPS) such as the dual core ARM Cortex A9
in Altera Cyclone V SoC FPGAs come together to offer unprecedented performance and integration benefts otherwise not realizable
in a single chip. VCA is a relatively new feld in Machine Vision; up to now it has mostly been implemented as a two-chip solution:
the ISP portion in a DSP or FPGA and the VCA algorithms running on a processor. System-on-Chip (SoC) FPGAs that incorporate
one or more hard processor systems along with FPGA fabric on a single chip now make it possible for a single device to run both ISP
and VCA applications at the same time. In the Altera Cyclone V SoC FPGAs, ISP data from the FPGA fabric is available to the HPS
through very low latency on chip interconnect for processor intensive video analytics computations, obviating the need for separate
ISP and VCA processing chips. Te dual ARM Cortex A9 processors not only provide enough computing power, but also enable a
programmer and OS-friendly environment for rapid development and deployment of VCA applications
GMT+8, 2026-5-23 00:16 , Processed in 0.031112 second(s), 19 queries .
