查看: 1952|回复: 5
Altera推荐的寄存器的写法
陈飞龙 发表于 2017-10-29 17:48:02 | 显示全部楼层 |阅读模式
Verilog Register with High Power-Up Value
reg q = 1’b1; //q has a default value of ‘1’
always @ (posedge clk)
q <= d;
 楼主| 陈飞龙 发表于 2017-10-29 17:48:35 | 显示全部楼层
直接不需要复位端口,在定义变量时直接赋值
 楼主| 陈飞龙 发表于 2017-10-29 17:48:59 | 显示全部楼层
VHDL Register with High Power-Up Level
SIGNAL q : STD_LOGIC := '1'; -- q has a default value of '1'
PROCESS (clk, reset)
BEGIN
IF (rising_edge(clk)) THEN
q <= d;
END IF;
END PROCESS;
芙蓉王 发表于 2017-10-30 09:25:12 | 显示全部楼层
Altera推荐的寄存器的写法
zhangyukun 发表于 2017-10-30 09:27:42 | 显示全部楼层
Altera推荐的寄存器的写法
zxopenljx 发表于 2025-1-7 15:40:36 | 显示全部楼层
Altera推荐的寄存器的写法
GMT+8, 2026-5-19 22:02 , Processed in 0.032069 second(s), 19 queries .
