查看: 3058|回复: 7
ALtera推荐的两段式状态机的写法
陈飞龙 发表于 2017-11-1 19:48:20 | 显示全部楼层 |阅读模式
Verilog-2001 State Machine
module verilog_fsm (clk, reset, in_1, in_2, out);
input clk, reset;
input [3:0] in_1, in_2;
output [4:0] out;
parameter state_0 = 3'b000;
parameter state_1 = 3'b001;
parameter state_2 = 3'b010;
parameter state_3 = 3'b011;
parameter state_4 = 3'b100;
reg [4:0] tmp_out_0, tmp_out_1, tmp_out_2;
reg [2:0] state, next_state;
always @ (posedge clk or posedge reset)
if (reset)
state <= state_0;
state <= next_state;
always @ (*)
tmp_out_0 = in_1 + in_2;
tmp_out_1 = in_1 - in_2;
case (state)
state_0: begin
tmp_out_2 = in_1 + 5'b00001;
next_state = state_1;
state_1: begin
if (in_1 < in_2) begin
next_state = state_2;
tmp_out_2 = tmp_out_0;
else begin
next_state = state_3;
tmp_out_2 = tmp_out_1;
state_2: begin
tmp_out_2 = tmp_out_0 - 5'b00001;
state_3: begin
tmp_out_2 = tmp_out_1 + 5'b00001;
next_state = state_0;
state_4:begin
tmp_out_2 = in_2 + 5'b00001;
default:begin
tmp_out_2 = 5'b00000;
endcase
assign out = tmp_out_2;
 楼主| 陈飞龙 发表于 2017-11-1 19:49:36 | 显示全部楼层
An equivalent implementation of this state machine can be achieved by using ‘define instead of
the parameter data type, as follows:
‘define state_0 3'b000
‘define state_1 3'b001
‘define state_2 3'b010
‘define state_3 3'b011
‘define state_4 3'b100
 楼主| 陈飞龙 发表于 2017-11-1 19:50:49 | 显示全部楼层
可以用宏定义的方式代替参数
zhangyukun 发表于 2017-11-2 09:28:35 | 显示全部楼层
ALtera推荐的两段式状态机的写法
芙蓉王 发表于 2017-11-2 09:31:13 | 显示全部楼层
ALtera推荐的两段式状态机的写法
 楼主| 陈飞龙 发表于 2017-11-2 18:35:01 | 显示全部楼层
迷之微笑!!!!!!!!!!!
zxopenljx 发表于 2025-1-21 18:01:26 | 显示全部楼层
ALtera推荐的两段式状态机的写法
GMT+8, 2026-5-22 10:18 , Processed in 0.032451 second(s), 20 queries .
