查看: 2005|回复: 4
Cyclone II 电源特性和电源管脚
小舍YZ 发表于 2017-11-9 15:48:38 | 显示全部楼层 |阅读模式
1/2 the Static Power 1/2 the Dynamic Power Zero Inrush Current Hot-Socketing Support Fewer Required Power Supplies
The Cyclone II Total Advantage
#1 in Low Power—Half the power of competing 90-nm low-cost FPGAs.
#1 in Price—No price premiums for lower power. Competing 90-nm low-cost FPGAs have a price premium to obtain lower power devices.
#1 in Performance—60 percent higher performance than competing 90-nm low-cost FPGAs. Obtain low power and high performance from a single FPGA.
另外Cyclone还有防浪涌,热插拔,上电复位,PLL电源,以及其他IO方面的电源特性。
比如:
The IOE registers in each I/O block share the same source for clear or preset. You can program preset or clear for each individual IOE, but both features cannot be used simultaneously. You can also program the
registers to power up high or low after configuration is complete. If programmed to power up low, an asynchronous clear can control the registers. If programmed to power up  high, an asynchronous preset can
This feature pr events the inadvertent activation of another device’s active-low input upon power up. If one register in an IOE uses a preset or clear signal then all registers in the IOE must use that same signal if
they require preset or clear. Additionally a synchronous reset signal is availabl e for the IOE registers.
Cyclone 电源管脚:
VCCINT:内核电压。通常与FPGA芯片所采用的工艺有关,例如130nm工艺为1.5V,90nm工艺为1.2V。
VCCIO:端口电压。一般为3.3V,还可以支持选择多种电压,如1.8V、1.5V等。
VREF:参考电压。
VCC_PLL:锁相环管脚电压,直接连VCCIO。
VCCA_PLL:锁相环模拟电压,一般通过滤波器接到VCCINT上。
GNDA_PLL:锁相环模拟地。
GNDD_PLL:锁相环数字地。
JTAG  AS   VCC电源
点评
海!外直播 t.cn/RxmJTRo 禁闻视频 t.cn/RxrADk4 60年,中国做两件事:一公私合营人民公社.二否定公私合营否定人民公社.前30年,冤假错案超过三千年总和.后30年,贪污腐败超过三千年总和.前30年折腾政治.后30年,折腾经   发表于 2017-11-13 16:13
zhangyukun 发表于 2017-11-10 09:40:24 | 显示全部楼层
zxopenljx 发表于 2020-6-28 11:39:45 | 显示全部楼层
GMT+8, 2026-5-22 23:27 , Processed in 0.033514 second(s), 22 queries .
