查看: 1904|回复: 0
新手急求!!!!!望高手给与解答,跪求,高手给指点迷津!!!!!!!!!!!
郝鑫 发表于 2011-5-7 19:58:33 | 显示全部楼层 |阅读模式
erilog, 警告
新手急求!!!!!望高手给与解答
module count10a(outa,couta,en,clk,rst);
output [3:0]outa;
output couta;
reg[3:0]countb;
reg couta;
assign outa=countb;
input clk,rst,en;
always@(*)
if(!rst)        begin
                countb<=4'b0;
                couta<=1'b0;
        if(en)
                        if(countb==9)
                                        countb<=4'b0;
                                        couta<=~couta;
                                        countb<=countb+1;
                        countb<=4'b0;
                        couta<=1'b0;
在用quartus编译的时候出现这个警告:Warning: Verilog HDL Always Construct warning at count10a.v(9): variable "couta" may not be assigned a new value in every possible path through the Always Construct.  Variable "couta" holds its previous value in every path with no new value assignment, which may create a combinational loop in the current design.希望高手给与解决的方案,警告出现在红字上面
GMT+8, 2026-5-23 23:50 , Processed in 0.031261 second(s), 23 queries .
