查看: 2603|回复: 5
VHDL——如何写简单的testbench
fpga_feixiang 发表于 2017-12-4 10:35:59 | 显示全部楼层 |阅读模式
六进制计数器的代码
[csharp] view plain copy
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
--use ieee.std_logic_unsigned.all;
entity cnt6 is
  port
  (clr,en,clk :in std_logic;
  q  ut  std_logic_vector(2 downto 0)
end entity;
architecture rtl of cnt6 is
signal tmp  :std_logic_vector(2 downto 0);
  process(clk)
--    variable q6:integer;
      if(clk'event and clk='1') then
        if(clr='0')then
          tmp<="000";
        elsif(en='1') then
          if(tmp="101")then
            tmp<="000";
            tmp<=unsigned(tmp)+'1';
          end if;
        end if;
      end if;
      q<=tmp;
--      qa<=q(0);
--     qb<=q(1);
--     qc<=q(2);
  end process;
end rtl;
六进制计数器testbench的代码
library ieee;
entity cnt6_tb is
end cnt6_tb;
architecture rtl of cnt6_tb is
  component cnt6
    port(
  end component;
  signal clr  :std_logic:='0';
  signal en   :std_logic:='0';
  signal clk  :std_logic:='0';
  signal  q   :std_logic_vector(2 downto 0);
  constant clk_period :time :=20 ns;
    instant:cnt6 port map
      clk=>clk,en=>en,clr=>clr,q=>q
  clk_gen:process
    wait for clk_period/2;
    clk<='1';
    clk<='0';
  end process;
  clr_gen:process
    clr<='0';
    wait for 30 ns;
    clr<='1';
    wait;
  end process;
  en_gen:process
    en<='0';
    wait for 50ns;
    en<='1';
    wait;
  end process;
end rtl;
其实testbench也有自己固定的一套格式,总结如下:
--测试平台文件(testbench)的基本结构
library ieee;
entity test_bench is      --测试平台文件的空实体(不需要端口定义)
end test_bench;
architecture tb_behavior of test_bench is
    component entity_under_test         --被测试元件的声明
        port(
        list-of-ports-theri-types-and-modes
    end component;
    instantiation:entity_under_test port map
        port-associations
    process()       --产生时钟信号
    end process;
    process()       --产生激励源
    end process;
end tb_behavior;
--简单计数程序源码
library ieee;
entity sim_counter is
    port(
        clk     :in     std_logic;
        reset   :in     std_logic;
        count   ut    std_logic_vector(3 downto 0)
end entity;
architecture behavioral of sim_counter is
signal temp :std_logic_vector(3 downto 0);
    process(clk,reset)
        if reset='1' then
            temp<="0000";
        elsif clk'event and clk='1' then
            temp<=temp+1;
        end if;
    end process;
    count<=temp;
end behavioral;
--简单计数程序,测试文件代码(testbench)
library ieee;
use ieee.numeric_std.all;
entity counter_tb_vhd is            --测试平台实体
end counter_tb_vhd;
architecture behavior of counter_tb_vhd is
    --被测试元件(DUT)的声明
    component sim_counter
    port(
        clk :in std_logic;
    end component;
    --输入信号
    signal clk:std_logic:='0';
    signal reset :std_logic:='0';
    --输出信号
    signal count    :std_logic_vector(3 downto 0);
    constant clk_period :time   :=20 ns;        --时钟周期的定义
    dut:sim_counter port map(
        clk=>clk,reset=>reset,counter=>counter
    clk_gen:process
        clk='1';
        clk='0';
    end process;
    tb:process      --激励信号
        wait for 20 ns;
        reset<='1';
        wait for 20 ns;
        reset<='0';
        wait for 200 ns;
        wait;       --will wait forever;
    end process;
end;
--激励信号的产生方式
--1.以一定的离散时间间隔产生激励信号的波形
--2.基于实体的状态产生激励信号,也就是说基于实体的输出响应产生激励信号
--两种常用的复位信号
--1.周期性的激励信号,如时钟
--2.时序变化的激励型号,如复位
--eg.产生不对称时钟信号
    w_clk<='0' after period/4 when w_clk='1' else
           '1' after 3*period/4 when w_clk='0' else
           '0';
--eg.产生堆成时钟信号,process语句
clk_gen1:process
constan clk_period  := 40 ns;
    clk='1';
    clk='0';
end process;
如果自己不想写这些testbench的这些固定格式,可以在SIE里自动生成testbench文件的模板
步骤:New Surce -> VHDL Test Bench, 然后才会生成testbench
自动生成的testbench模板格式如下:
-- Copyright (C) 1991-2008 Altera Corporation
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, Altera MegaCore Function License
-- Agreement, or other applicable license agreement, including,
-- without limitation, that your use is for the sole purpose of
-- programming logic devices manufactured by Altera and sold by
-- Altera or its authorized distributors.  Please refer to the
-- applicable agreement for further details.
-- This file contains a Vhdl test bench template that is freely editable to
-- suit user's needs .Comments are provided in each section to help the user
-- fill out necessary details.
-- Generated on "03/13/2011 20:05:04"
-- Vhdl Test Bench template for design  :  cnt6
-- Simulation tool : ModelSim (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY cnt6_vhd_tst IS
END cnt6_vhd_tst;
ARCHITECTURE cnt6_arch OF cnt6_vhd_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC;
SIGNAL clr : STD_LOGIC;
SIGNAL en : STD_LOGIC;
SIGNAL q : STD_LOGIC_VECTOR(2 DOWNTO 0);
COMPONENT cnt6
    PORT (
    clk : IN STD_LOGIC;
    clr : IN STD_LOGIC;
    en : IN STD_LOGIC;
    q : OUT STD_LOGIC_VECTOR(2 DOWNTO 0)
END COMPONENT;
BEGIN
    i1 : cnt6
    PORT MAP (
-- list connections between master ports and signals
    clk => clk,
    clr => clr,
    en => en,
    q => q
init : PROCESS
-- variable declarations
BEGIN
        -- code that executes only once
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
        -- code executes for every event on sensitivity list
WAIT;
END PROCESS always;
END cnt6_arch;
zhiweiqiang33 发表于 2017-12-9 14:50:12 | 显示全部楼层
zxopenhl 发表于 2017-12-10 09:49:47 | 显示全部楼层
这个可以借鉴借鉴!
奋斗的小孩 发表于 2017-12-23 19:54:13 | 显示全部楼层
不会写激励的,可以参考一下呦
小丽呀小丽 发表于 2017-12-23 20:05:05 | 显示全部楼层
仿真成功··············
zxopenljx 发表于 2025-2-19 17:37:51 | 显示全部楼层
GMT+8, 2026-5-22 10:18 , Processed in 0.037854 second(s), 20 queries .
