查看: 1487|回复: 1
tlc5620的时序问题,各位看看问题出在哪里
追风的云 发表于 2017-12-6 14:51:30 | 显示全部楼层 |阅读模式
module tlc5620 (
               input clk_50MHz,
                                        input rst_n,
                                        output da_clk,
                                        output da_load,
                                        output da_ldac,
                                        output da_data
        wire clk_1MHz;
        reg [7:0] data;
   reg [3:0] num;
   always @(posedge clk_1MHz or negedge rst_n)
           if(!rst_n)
                   num<=4'd0;
                        data<=8'd100;
                   if(num==12)
                          num<=4'd0;
                           num<=num+1'd1;
        reg da_data_r;
        always @(posedge clk_50MHz or negedge rst_n)
           if(!rst_n)
                   da_data_r<=1'b0;
                   case(num)
                           4'd0:da_data_r<=1'b0;
                                4'd1:da_data_r<=1'b0;
                                4'd2:da_data_r<=1'b0;
                                4'd3:da_data_r<=data[7];
                                4'd4:da_data_r<=data[6];
                                4'd5:da_data_r<=data[5];
                                4'd6:da_data_r<=data[4];
                                4'd7:da_data_r<=data[3];
                                4'd8:da_data_r<=data[2];
                                4'd9:da_data_r<=data[1];
                                4'd10:da_data_r<=data[0];
                                4'd11:da_data_r<=1'b0;
                                4'd12:da_data_r<=1'b0;
                                default:;
                        endcase
   assign da_data=da_data_r;
        assign da_clk=clk_1MHz;
        assign da_load=(num==11)?1'b0:1'b1;
        assign da_ldac=(num==12)?1'b0:1'b1;
        pll pll_dut (
                    .areset(rst_n),
                    .inclk0(clk_50MHz),
                    .c0(clk_1MHz)
zxopenhl 发表于 2017-12-6 19:11:15 | 显示全部楼层
你可以讲仿真波形,放在这里看看,这样更容易找问题
GMT+8, 2026-5-23 03:00 , Processed in 0.041413 second(s), 20 queries .
