查看: 1424|回复: 1
大侠求助,万急!!!!
shouhe 发表于 2011-5-9 23:14:03 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity sram_fifo is
port(
clk:in std_logic;
clr:in std_logic;
datain:in std_logic_vector(15 downto 0);
sh:in std_logic;
wr_clk:in std_logic;--be equal to dataclk
--USB signal
start:in std_logic;
flag_full:in std_logic;
u_ifclkut std_logic;
u_addr1ut std_logic;
u_addr0ut std_logic;
slwrut std_logic;
dataoutut std_logic_vector(15 downto 0);
SLRD:OUT STD_LOGIC;
--led
led0ut std_logic;
led1ut std_logic;
led2ut std_logic;
led3ut std_logic;
--sram:is61lv51216 signal
sram_addrut std_logic_vector(17 downto 0);
sram_data:inout std_logic_vector(15 downto 0);
sram_ub:out std_logic;
sram_lb:out std_logic;
oe:out std_logic;--low valid
we:out std_logic;--low valid
ce:out std_logic--low valid
end entity;
architecture behav of sram_fifo is
signal sh_en:std_logic;
type states is(idle,wr_begin,wr_on,wr,wr_end,rd_begin,rd_on,rd,rd_end);
signal current_state:states;
signal sram_addr_s:std_logic_vector(17 downto 0);
SIGNAL SRAM_DATA_FIFO:STD_LOGIC_VECTOR(15 downto 0);
signal usb_data_fifo:std_logic_vector(15 downto 0);
signal wr_flag:std_logic;
signal rd_flag:std_logic;
--read 7680 values per frame:sh_en :enable
a0:
process(wr_clk,sh)
variable cnt1:integer range 0 to 7681:=0;
if(sh='0')then
if(wr_clk'event and wr_clk='1')then
if(cnt1=7681)then
cnt1:=cnt1;
else cnt1:=cnt1+1;
  if(cnt1<=7680)then
    sh_en<='0';
    sh_en<='1';
  end if;
end if;
end if;
cnt1:=0;
sh_en<='1';
end if;
end process a0;
--write and read respectively
a1:
process(clk,start)
if(clk'event and clk='1')then
if(clr='1')then
oe<='1';
we<='1';
sram_addr_s<="000000000000000000";
wr_flag<='0';
rd_flag<='0';
u_addr1<='0';
u_addr0<='0';
slwr<='1';
led0<='0';
led1<='0';
led2<='0';
led3<='0';
--cnt2:=0;
current_state<=idle;
case current_state is
when idle=>     wr_flag<='0';
                rd_flag<='0';
                LED0<='0';
                led1<='0';
                led2<='0';
                led3<='0';
                oe<='1';
                we<='1';
                sram_addr_s<="000000000000000000";地址从1开始写的,没用地址0.
                u_addr1<='0';
                u_addr0<='0';
                slwr<='1';
                if(start='1')then
                current_state<=wr_begin;
                end if;
when wr_begin=>  wr_flag<='1';
                 if(sh_en='0')then
                  current_state<=wr_on;
                 end if;
when wr_on=>    if(sh_en='0')then
                   sram_addr_s<=sram_addr_s+'1';
                   SRAM_DATA_FIFO<=datain;
                   we<='1';
                   oe<='0';
                   current_state<=wr;
                end if;
when wr      => if(sram_addr_s/="100101100000000000")then
                  we<='0';
                  oe<='0';
                  led0<='1';
                  we<='1';
                  oe<='1';
                  wr_flag<='0';
                  current_state<=wr_end;
                end if;
when wr_end  => wr_flag<='0';
                current_state<=rd_begin;
                led2<='1';
when rd_begin=> u_addr1<='1';
                u_addr0<='0';
                oe<='0';
                we<='1';
                wr_flag<='0';
                rd_flag<='1';
                current_state<=rd_on;
when rd_on   => if(flag_full='1')then
                    slwr<='0';
                    dataout<=usb_data_fifo;
                    current_state<=rd;
                    slwr<='1';
                end if;
when rd      => --slwr<='1';
                  oe<='0';
                  we<='1';
                  led3<='1';
                  --SLWR<='1';
                  oe<='1';
                  we<='1';
                  led1<='1';
                  rd_flag<='0';
                  current_state<=rd_end;
                end if;
when rd_end  => slwr<='1';
                wr_flag<='0';
                rd_flag<='0';
                if(start='0')then
                end if;
when others  => current_state<=idle;
end case;
end if;
end if;
end process;
sram_data<=SRAM_DATA_FIFO when (wr_flag='1' and rd_flag='0') else (others=>'Z');
usb_data_fifo<=sram_data when (rd_flag='1' and wr_flag='0') else (others=>'0');
sram_addr<=sram_addr_s;
ce<='1';
SLRD<='1';
u_ifclk<=wr_clk;
--oe<='0';
sram_ub<='0';
sram_lb<='0';
end behav;
这是我用FPGA控制SRAM读写,然后传给USB(68013a),我想问一下我的程序哪里出错了,为什么读不出数来呢,从USB上读出来的都是FF.
start来自USB,FPGA接收到后就开始写SRAM,写到指定书目后即153600个数据后,停止写,开始读数,并给USB传输。SH_EN是一帧数据中的有用信号标志。低电平说明是信号有效。求大侠们帮忙呀!小弟在此谢过了......
 楼主| shouhe 发表于 2011-5-10 12:12:18 | 显示全部楼层
我检查了一下,CE管脚忘记置低电平了,此外再把程序中如下改一下就好了
                   we<='0';
                   oe<='1';
                   current_state<=wr;
                end if;
                  we<='1';
                  oe<='1';
                  led0<='1';
                  we<='1';
                  oe<='1';
                  wr_flag<='0';
                end if;
GMT+8, 2026-5-23 23:49 , Processed in 0.057376 second(s), 21 queries .
