查看: 1691|回复: 0
无法解决啊
谢修森 发表于 2011-5-11 20:10:15 | 显示全部楼层 |阅读模式
-----4选1
     LIBRARY   IEEE;
     USE IEEE.STD_LOGIC_1164.ALL;
      entity  project5 is
      port(a,b,i0,i1,i2,i3:in std_logic;
                  data_outut std_logic);
      end project5;
      architecture  set41 of project5 is
          process(a,b,i0,i1,i2,i3)
           variable sel:integer range 0 to 3;
           sel:=0;
        if a='1' then
            sel:=sel+1;
        end if;
        if b='1' then
            sel:=sel+2;
       end if;
      data_out<=i0 when sel=0 else
                i1 when sel=1 else
                i2 when sel=2 else
                i3 when sel=3;
      end process;
        end set41;
      ---提示错误         Error: Peak virtual memory: 212 megabytes
GMT+8, 2026-5-24 00:42 , Processed in 0.042373 second(s), 21 queries .
