查看: 1770|回复: 1
跪求VHDL高手啊
bluesnowvictor 发表于 2011-5-13 16:06:55 | 显示全部楼层 |阅读模式
我编的是一个时钟秒钟的设置
敏感信号有时钟,上设置键,下设置键
一开始我全部弄在一个process里面
就是如果在set状态,(upset'event and upset='0')秒钟自动加1,(downset'event and downset='0')秒钟自动减1,正常情况下(clk'event and clk='1')秒钟自动加1
结果报错,说一个process里面不能有2个以上的边沿触发;
如果我改写了,将上述3个边沿触发放在了3个process里面,结果报错,不能有2个以上并行的process对同一个信号进行赋值;
再然后我就设置了一个变量,先3个process对变量赋值,变量再给信号赋值,结果报错说不能在process外定义变量。
上次提问了一次,最后还是没有解决问题,现在仿真错误,程序如下:
library ieee;
use ieee.std_logic_1164.all;
entity second is
port
(clk0,clk,reset,setsecond,upset,downset:in std_logic;
enminut std_logic;
dh:buffer std_logic_vector (3 downto 0);
dl:buffer std_logic_vector (3 downto 0));
end;
architecture action of second is
signal upset_r,downset_r:std_logic:='1';
process(reset,clk,setsecond,upset,downset,dh,dl,upset_r,downset_r)
if reset='0' then
        dh<="0000";
        dl<="0000";
elsif setsecond='1' then
        if (upset_r='1' and upset='0') then
                if dl=9 then
                        dl<="0000";
                        if dh>=5 then
                                dh<="0000";
                                dh<=dh+1;
                        end if;
                        dl<=dl+1;
                end if;
        elsif (downset_r='1' and downset='0') then
                if dl=0 then
                        dl<="1001";
                        if dh=0 then
                                dh<="0101";
                                dh<=dh-1;
                        end if;
                        dl<=dl-1;
                end if;
        end if;
        if dl="1001" and dh="0101" then
                enmin<='0';
                enmin<='1';
        end if;
        if (clk'event and clk='1') then
                if dl=9 then
                        dl<="0000";
                        if dh>=5 then
                                dh<="0000";
                                dh<=dh+1;
                        end if;
                        dl<=dl+1;
                end if;
        end if;
end if;
end process;
process(clk0)
if (clk0'event and clk0='1') then
        upset_r<=upset;
        downset_r<=downset;
end if;
end process;
end;
upset和downset的时候还是出错。clk0是200Hz信号,clk是1Hz的信号。
wangjinzeng 发表于 2011-6-2 16:21:44 | 显示全部楼层
library ieee;
use ieee.std_logic_arith.all;
entity second is
port
(clk:in std_logic;--200HZ
enmin: out std_logic;
dhut std_logic_vector (2 downto 0);--0~5,not need (3 downto 0)
dlut std_logic_vector (3 downto 0));
end;
signal clk0:std_logic;--1HZ;
signal clk1:std_logic;--1hz;
signal clk_p:std_logic;--rising clk
signal setsecond_p:std_logic;
signal upset1,upset2:std_logic;
signal upset_p:std_logic;
signal downset1,downset2:std_logic;
signal downset_p:std_logic;
signal step:std_logic_vector(3 downto 0);
process(clk)
constant min:integer:=99;
variable i:integer range 0 to min;
                if(clk'event and clk='1')then
                        if(i>=min)then
                                i:=0;
                                clk0<=not clk0;
                                i:=i+1;
                        end if;
                end if;
        end process;
process(clk)
                        clk1<=clk0;
                end if;
        end process;
clk_p<=clk0 and(not clk1);
process(clk)
                        setsecond_p<=setsecond;
                end if;
        end process;
process(clk)
                        upset1<=upset;
                end if;
        end process;
process(clk)
                        upset2<=upset1;
                end if;
        end process;
upset_p<=upset1 and(not upset2);
process(clk)
                        downset1<=downset;
                end if;
        end process;
process(clk)
                        downset2<=downset1;
                end if;
        end process;
downset_p<=downset1 and(not downset2);
process(clk,reset)
        constant idle:         std_logic_vector(3 downto 0):="0001";
        constant data_up:      std_logic_vector(3 downto 0):="0010";
        constant data_down:    std_logic_vector(3 downto 0):="0100";
        constant data_auto_up: std_logic_vector(3 downto 0):="1000";
        variable h:std_logic_vector(2 downto 0);
        variable l:std_logic_vector(3 downto 0);
                if(reset='1')then
                        enmin<='0';
                        h:=(others=>'0');
                        l:=(others=>'0');
                        step<=idle;
                elsif(clk'event and clk='1')then
                        case step is
                                when idle=>
                                        enmin<='0';
                                        if(setsecond_p='1')then
                                                if(upset_p='1')then
                                                        step<=data_up;
                                                elsif(downset_p='1')then
                                                        step<=data_down;
                                                        step<=idle;
                                                end if;
                                                if(clk_p='1')then
                                                        step<=data_auto_up;
                                                        step<=idle;
                                                end if;
                                        end if;
                                when data_up=>
                                        step<=idle;
                                        if(l<9)then
                                                l:=l+1;
                                                enmin<='0';
                                        elsif(l>=9)then
                                                l:=(others=>'0');
                                                if(h>=5)then
                                                        h:=(others=>'0');
                                                        enmin<='1';
                                                elsif(h<5)then
                                                        h:=h+1;
                                                        enmin<='0';
                                                end if;
                                        end if;
                                when data_auto_up=>
                                        step<=idle;
                                        if(l<9)then
                                                l:=l+1;
                                                enmin<='0';
                                        elsif(l>=9)then
                                                l:=(others=>'0');
                                                if(h>=5)then
                                                        h:=(others=>'0');
                                                        enmin<='1';
                                                elsif(h<5)then
                                                        h:=h+1;
                                                        enmin<='0';
                                                end if;
                                        end if;
                                when data_down=>
                                        step<=idle;
                                        if(l>0)then
                                                l:=l-1;
                                                enmin<='0';
                                        elsif(l=0)then
                                                l:="1001";--9
                                                if(h>=1)then
                                                        h:=h-1;
                                                        enmin<='0';
                                                elsif(h=0)then
                                                        h:="101";--5
                                                        enmin<='1';
                                                end if;
                                        end if;
                                when others=>
                                        enmin<='0';
                                        h:=(others=>'0');
                                        l:=(others=>'0');
                                        step<=idle;
                        end case;
                end if;
                dh<=h;
                dl<=l;
        end process;
end;
看你真可怜,故花几分钟给你写了代码。
里面没有所谓的1HZ时钟信号输入,因为它完全可以由200HZ信号派生。你的buffer std_logic_vector 信号输出我直接改成了out std_logic_vector 。因为用buffer信号有很多讲究。还有就是你的dh输出是0~5,用std_logic_vector (2 downto 0)就足够了,没必要用std_logic_vector (3 downto 0)。这里面我没加消抖按键处理,有空就自己加上吧。
GMT+8, 2026-5-23 23:50 , Processed in 0.031394 second(s), 21 queries .
