查看: 1378|回复: 1
求助一下关于串口发送32位数据的问题
woshilaoshuai 发表于 2018-4-18 17:48:14 | 显示全部楼层 |阅读模式
下面是我用Verilog写的发送8位数据的uart通信,key1是开发板上按键,按下则把设定好的8位数据发给上位机。但是我现在需要传送32位数据,应该是把32位分为4组,一组8个依次发送,但是我是新手,不知道怎么加状态判断,让 [31:0] tx_data1的4组依次发送,哪位大神帮我修改一下我的程序,或者给我详细讲解一下,让它可以传送32位数据。
module uart (
input clk
input key1,
input rst_n,
output reg txd
parameter S1_IDLE=4'd0;
parameter S1_START=4'd1;
parameter S1_BIT0=4'd2;
parameter S1_BIT1=4'd3;
parameter S1_BIT2=4'd4;
parameter S1_BIT3=4'd5;
parameter S1_BIT4=4'd6;
parameter S1_BIT5=4'd7;
parameter S1_BIT6=4'd8;
parameter S1_BIT7=4'd9;
parameter S1_STOP=4'd10;
wire [7:0] tx_data1;
assign tx_data1=8'h5c;
reg [4:0] state;
reg [16:0] bit_timer;
always @ (posedge clk or negedge rst_n )
if(!rst_n)
state<=S1_IDLE;
bit_timer<=16'd0;
txd<=1'b1;
case (state)
S1_IDLE:
bit_timer<=16'd0;
txd<=1'b1;
if(!key1)
state<=S1_START;
state<=state;
S1_START:
txd<=1'b0;
if(bit_timer==16'd20833)
state<=S1_BIT0;
bit_timer<=16'd0;
state<=state;
bit_timer<=bit_timer+16'd1;
S1_BIT0:
txd<=tx_data1[0];
state<=S1_BIT1;
bit_timer<=16'd0;
state<=state;
S1_BIT1:
txd<=tx_data1[1];
state<=S1_BIT2;
bit_timer<=16'd0;
state<=state;
S1_BIT2:
txd<=tx_data1[2];
state<=S1_BIT3;
bit_timer<=16'd0;
state<=state;
S1_BIT3:
txd<=tx_data1[3];
state<=S1_BIT4;
bit_timer<=16'd0;
state<=state;
S1_BIT4:
txd<=tx_data1[4];
state<=S1_BIT5;
bit_timer<=16'd0;
state<=state;
S1_BIT5:
txd<=tx_data1[5];
state<=S1_BIT6;
bit_timer<=16'd0;
state<=state;
S1_BIT6:
txd<=tx_data1[6];
state<=S1_BIT7;
bit_timer<=16'd0;
state<=state;
S1_BIT7:
txd<=tx_data1[7];
state<=S1_STOP;
bit_timer<=16'd0;
state<=state;
S1_STOP:
txd<=1'b1;
state<=S1_IDLE;
bit_timer<=16'd0;
state<=state;
default:
state<=S1_IDLE;
endcase
GMT+8, 2026-5-22 22:00 , Processed in 0.040313 second(s), 24 queries .
