查看: 7743|回复: 1
QuartusII中编译双口RAM时出现的问题
lilanjun004 发表于 2011-5-17 17:22:54 | 显示全部楼层 |阅读模式
在项目中用了双口RAM,单独编译RAM时仿真结果正确,将RAM用在项目中编译时出现如下错误提示:
Error: WYSIWYG primitive "ram_block1a0" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a0" must have Port A, Address port or parameter specified
Error: WYSIWYG primitive "ram_block1a1" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a1" must have Port A, Address port or parameter specified
Error: WYSIWYG primitive "ram_block1a2" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a2" must have Port A, Address port or parameter specified
Error: WYSIWYG primitive "ram_block1a3" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a3" must have Port A, Address port or parameter specified
Error: WYSIWYG primitive "ram_block1a4" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a4" must have Port A, Address port or parameter specified
Error: WYSIWYG primitive "ram_block1a5" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a5" must have Port A, Address port or parameter specified
Error: WYSIWYG primitive "ram_block1a6" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a6" must have Port A, Address port or parameter specified
Error: WYSIWYG primitive "ram_block1a7" must use clk0 port
Error: WYSIWYG RAM primitive "ram_block1a7" must have Port A, Address port or parameter specified
在网上查的出现这种错误可能是没有给RAM加时钟信号,但是我已经给RAM加过时钟信号了,为什么还出现这种错误提示呢?盼解答。
 楼主| lilanjun004 发表于 2011-5-24 12:51:14 | 显示全部楼层
没人回答?自己回答一下吧,出错是因为RAM的输入端口信号不通,检查输入RAM的各路信号,只要信号全部是通路就OK了
GMT+8, 2026-5-24 00:39 , Processed in 0.047123 second(s), 24 queries .
