查看: 3517|回复: 2
请教:verilog hdl实现串口通信
hanyucb 发表于 2011-5-17 22:45:06 | 显示全部楼层 |阅读模式
最近学习,有一句程序看不懂。
module receive_test(clk, RxD,  RxD_data );
input clk, RxD;                // 系统时钟, 接收信号
output [7:0] RxD_data;        // 接收的数据,进入后级的 RAM 数据总线
reg [Baud8GeneratorAccWidth:0] Baud8GeneratorAcc;
reg [1:0] RxD_sync_inv;
reg [1:0] RxD_cnt_inv;
reg RxD_bit_inv;
reg [3:0] state;
reg [3:0] bit_spacing;
reg [7:0] RxD_data;
parameter ClkFrequency = 50_000_000; // 25MHz
parameter Baud = 9600;
// Baud generator (we use 8 times oversampling)
parameter Baud8 = Baud*8;
parameter Baud8GeneratorAccWidth = 16;
wire [Baud8GeneratorAccWidth:0] Baud8GeneratorInc =
((Baud8<<(Baud8GeneratorAccWidth-7))+(ClkFrequency>>8))/(ClkFrequency>>7);
always @(posedge clk)
   Baud8GeneratorAcc<=Baud8GeneratorAcc[Baud8GeneratorAccWidth-1:0] + Baud8GeneratorInc;
wire Baud8Tick = Baud8GeneratorAcc[Baud8GeneratorAccWidth];
if(Baud8Tick)
RxD_sync_inv <= {RxD_sync_inv[0], ~RxD};
// we invert RxD, so that the idle becomes "0",
// to prevent a phantom character to be received at startup
        if(Baud8Tick)
                if( RxD_sync_inv[1] && RxD_cnt_inv!=2'b11)
                        RxD_cnt_inv <= RxD_cnt_inv + 2'h1;
                else if(~RxD_sync_inv[1] && RxD_cnt_inv!=2'b00)
                        RxD_cnt_inv <= RxD_cnt_inv - 2'h1;
                if(RxD_cnt_inv==2'b00)
                        RxD_bit_inv <= 1'b0;
                else if(RxD_cnt_inv==2'b11)
                        RxD_bit_inv <= 1'b1;
wire next_bit = (bit_spacing==4'd10);
if(state==0)
        bit_spacing <= 4'b0000;
if(Baud8Tick)
        bit_spacing <= {bit_spacing[2:0] + 4'b0001} | {bit_spacing[3], 3'b000};
if(Baud8Tick)
case(state)
        4'b0000:
                if(RxD_bit_inv)
                        state <= 4'b1000;  // start bit found?
        4'b1000: if(next_bit) state <= 4'b1001;  // bit 0
        4'b1001: if(next_bit) state <= 4'b1010;  // bit 1
        4'b1010: if(next_bit) state <= 4'b1011;  // bit 2
        4'b1011: if(next_bit) state <= 4'b1100;  // bit 3
        4'b1100: if(next_bit) state <= 4'b1101;  // bit 4
        4'b1101: if(next_bit) state <= 4'b1110;  // bit 5
        4'b1110: if(next_bit) state <= 4'b1111;  // bit 6
        4'b1111: if(next_bit) state <= 4'b0001;  // bit 7
        4'b0001:
                if(next_bit)
                        state <= 4'b0000;  // stop bit
        default:
                state <= 4'b0000;
endcase
        if(Baud8Tick && next_bit && state[3])
                RxD_data <= {~RxD_bit_inv, RxD_data[7:1]};
最后一句RxD_data <= {~RxD_bit_inv, RxD_data[7:1]} 不知道怎么来了,望高手赐教!
slienttree 发表于 2011-5-19 17:27:12 | 显示全部楼层
uart接受模块的功能是将接收到串口数据写到一个8bit的寄存器RxD_data 中,再输出到I/O口。
RxD_data <= {~RxD_bit_inv, RxD_data[7:1]} 一句中是将新接收到的数据RxD_bit_inv写到寄存器RxD_data 的最高位上,同时将之前接收到的数据RxD_data[7:1]右移一位,当最后一个字节位被接收到后,一个完整的字节数据就被存储到寄存器当中了。
亲你可拉倒吧 发表于 2011-10-26 01:42:42 | 显示全部楼层
留着看看。
GMT+8, 2026-5-23 22:08 , Processed in 0.034190 second(s), 23 queries .
