查看: 1294|回复: 1
VGA Timings
fpga_feixiang 发表于 2018-12-2 15:11:34 | 显示全部楼层 |阅读模式
VGA Timings
The following table lists timing values for several popular resolutions.
Format        Pixel Clock
(MHz)        Horizontal (in Pixels)        Vertical (in Lines)
Active
Video        Front
Porch        Sync
Pulse        Back
Porch        Active
Video        Front
Porch        Sync
Pulse        Back
Porch
640x480, 60Hz        25.175        640        16        96        48        480        11        2        31
640x480, 72Hz        31.500        640        24        40        128        480        9        3        28
640x480, 75Hz        31.500        640        16        96        48        480        11        2        32
640x480, 85Hz        36.000        640        32        48        112        480        1        3        25
800x600, 56Hz        38.100        800        32        128        128        600        1        4        14
800x600, 60Hz        40.000        800        40        128        88        600        1        4        23
800x600, 72Hz        50.000        800        56        120        64        600        37        6        23
800x600, 75Hz        49.500        800        16        80        160        600        1        2        21
800x600, 85Hz        56.250        800        32        64        152        600        1        3        27
1024x768, 60Hz        65.000        1024        24        136        160        768        3        6        29
1024x768, 70Hz        75.000        1024        24        136        144        768        3        6        29
1024x768, 75Hz        78.750        1024        16        96        176        768        1        3        28
1024x768, 85Hz        94.500        1024        48        96        208        768        1        3        36
zhangyukun 发表于 2018-12-3 09:14:28 | 显示全部楼层
VGA Timings
GMT+8, 2026-5-22 17:20 , Processed in 0.036302 second(s), 20 queries .
