查看: 1415|回复: 2
库语句(Library)
fpga_feixiang 发表于 2019-2-15 15:23:06 | 显示全部楼层 |阅读模式
Library子句在本地环境下,为设计库定义一个逻辑名。
A library clause defines logical names for design libraries in the host environment.
语法(Syntax)
library library_name, ... ;
1
说明(Description)
Library语句为设计库定义一个逻辑名,可以被设计单元使用。库是一个实现相关(implementation-dependent)的存储,为了便于预先分析设计单元。
The library clause defines the logical names of design libraries, which are used by the design units. A library is an implementation-dependent storage facility for previously analyzed design units.
VHDL库常被作为主机文件系统的一个路径来实现。库名对应文件路径。
A VHDL library is usually implemented as a directory in the host file system. The library name is mapped to the pathname of that directory by the VHDL tool.
有两个预定的库,被隐式使用:std和work。Std库包含包Standard和Textio。Work库是工作库,存储所有用户创建的分析的设计单元。所有用户指定的包都存储在工作库Work中。
There are two predefined libraries, which are used implicitly in every design: Std and Work. The Std library contains the packages Standard and Textio. The Work library is a working library, where all user-created and analyzed design units are stored. Also user-specified packages are stored in the working library Work.
例程(Example)
library IEEE;
library Work, IpCores;
1
2
注释(Notes)
在主设计单元中使用library语句指定的库,对其相关联的次级单元可见。
A library specified in a library clause of the primary design unit
(entity, configuration or package) is visible in each secondary unit
(architecture or package body) associated to it.
Std库没有必要特别指定。所有的库包被自动包含在每个设计单元中。
Library Std need not to be specified. Both library packages are
automatically included in every design unit.
使用语句(Use)
实现直接的声明可见。
Achieves direct visibility of declarations that are visible by selection.
语法(Syntax)
use 库名[ .包名 ].项名;
1
use library_name[ .package_name ].item_name;
1
说明(Description)
Use子句使库中定义的名字对其他VHDL代码区域可见。Use语句一般写在实体的头部,或者配置的头部。
The use clause makes names defined in a library directly visible within another region of the VHDL code. The use clause is typically written at the top of an entity (giving access to common definitions from a package) or at the top of a configuration (giving access to the entities and architectures in a library).
Use子句指定其指定的项名可见。如果要使包中所有的声明可见,可以使用保留字all。
The item_name specified in the use clause, specifies the item that will be visible. If a designer wants to have all declarations in a package visible, then the item_name should be substituted by the reserved word all.
Use子句对其紧跟的设计单元和次设计单元立即生效。如果文件包含多余一个设计单元,则每个设计单元必须有他自己的use语句。也就是说,文件中use语句表示全局性的。
The use clause is valid for the design unit immediately following it and for all secondary design units assigned to this design unit (if it is a primary design unit). If a file contains more than one design unit, then each design unit must have its own use clauses. In other words, use clauses are not global within a file.
例程(Example)
use IEEE.std_logic_1164.all;
use WORK.ArithOp.Add;
use WORK.all
1
2
3
预定义包(Predefined Packages)
VHDL LRM提供了两个预定义包:Standard和TEXTIO
The VHDL LRM provides two predefined packages: Standard and TEXTIO.
包Std_logic_1164用来扩展VHDL为一个多值逻辑。基于包Std_logic_1164,包Numeric_std提供了数字数据的标准数据类型和运算符,
The package Std_logic_1164 has to be used to extend the VHDL into a multi-value logic. The package Numeric_std provides standard data types and operations for numeric data, based on the multi-value logic defined in Std_logic_1164.
标准包(Standard Package)
标准包预定义了数字类型,子类型和函数。
The Standard package predefines a number of types, subtypes, and functions.
说明(Description)
标准包是VHDL标准的一部分。包中定义了基本类型,子类型,函数,以及每种(子)类型的运算符。
The Standard package is part of the VHDL standard. This package contains definitions for basic types, subtypes, and functions, and the operators available for each of the (sub)types defined.
标准是隐式使用的,不需要用use子句来特别声明。
Use of the Standard package is implicitly assumed by every VHDL simulator and compiler and need not to be explicitly declared by the use clause.
package standard is
  type boolean is (false,true);
  type bit is ('0', '1');
  type character is (
    nul, soh, stx, etx, eot, enq, ack, bel,
    bs,  ht,  lf,  vt,  ff,  cr,  so,  si,
    dle, dc1, dc2, dc3, dc4, nak, syn, etb,
    can, em,  sub, esc, fsp, gsp, rsp, usp,
    '0', '1', '2', '3', '4', '5', '6', '7',
    '8', '9', ':', ';', '<', '=', '>', '?',
    '@', 'A', 'B', 'C', 'D', 'E', 'F', 'G',
    'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O',
    'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W',
    'X', 'Y', 'Z', '[', '\', ']', '^', '_',
    '`', 'a', 'b', 'c', 'd', 'e', 'f', 'g',
    'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o',
    'p', 'q', 'r', 's', 't', 'u', 'v', 'w',
    'x', 'y', 'z', '{', '|', '}', '~', del);
    -- VHDL'93 includes all 256 ASCII characters
  type severity_level is (note, warning, error, failure);
  type integer is range -2147483647 to 2147483647;
  type real is range -1.0E308 to 1.0E308;
  type time is range -2147483647 to 2147483647
    units
      fs;
      ps = 1000 fs;
      ns = 1000 ps;
      us = 1000 ns;
      ms = 1000 us;
      sec = 1000 ms;
      min = 60 sec;
      hr = 60 min;
    end units;
  subtype delay_length is time range 0 fs to time'high;
  impure function now return delay_length;
  function now return time;    -- VHDL'87 only
  subtype natural is integer range 0 to integer'high;
  subtype positive is integer range 1 to integer'high;
  type string is array (positive range <>) of character;
  type bit_vector is array (natural range <>) of bit;
  type file_open_kind is (
    read_mode,
    write_mode,
    append_mode);
  type file_open_status is (
    open_ok,
    status_error,
    name_error,
    mode_error);
  attribute foreign: string;
end standard;
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
注释(Notes)
用户不允许修改标准包的内容。
The user is not allowed to modify the contents of the Standard
package.
TEXTIO包(TEXTIO Package)
Textio包中的的类型和子程序,用来支持操作文本文件的标准化I/O。
Package Textio contains declarations of types and subprograms that support formatted I/O operations on text files.
说明(Description)
Textio允许读取和吸入ASCII文本文件。是LRM的一部分,在库Std中。
Textio is a VHDL package that allows the reading and writing of ASCII text files from VHDL. Textio is part of the LRM, and is in the library Std.
package TEXTIO is
  type LINE is access string;
  type TEXT is file of string;
  type SIDE is (right, left);
  subtype WIDTH is natural;
  file input : TEXT open READ_MODE is "STD_INPUT";
  file output : TEXT open WRITE_MODE is "STD_OUTPUT";
  procedure READLINE(file F: TEXT; L: out LINE);
  procedure READ(L:inout LINE; VALUE: out bit; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out bit);
  procedure READ(L:inout LINE; VALUE: out bit_vector; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out bit_vector);
  procedure READ(L:inout LINE; VALUE: out BOOLEAN; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out character; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out character);
  procedure READ(L:inout LINE; VALUE: out integer; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out integer);
  procedure READ(L:inout LINE; VALUE: out real; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out real);
  procedure READ(L:inout LINE; VALUE: out string; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out string);
  procedure READ(L:inout LINE; VALUE: out time; GOOD : out BOOLEAN);
  procedure READ(L:inout LINE; VALUE: out time);
  procedure WRITELINE(file F : TEXT; L : inout LINE);
  procedure WRITE(L :inout LINE; VALUE : in bit;
                  JUSTIFIED: in SIDE := right;
                  FIELD: in WIDTH := 0);
  procedure WRITE(L : inout LINE; VALUE : in bit_vector;
  procedure WRITE(L : inout LINE; VALUE : in BOOLEAN;
  procedure WRITE(L : inout LINE; VALUE : in character;
  procedure WRITE(L : inout LINE; VALUE : in integer;
  procedure WRITE(L : inout LINE; VALUE : in real;
                  FIELD: in WIDTH := 0;
                  DIGITS: in NATURAL := 0);
  procedure WRITE(L : inout LINE; VALUE : in string;
  procedure WRITE(L : inout LINE; VALUE : in time;
                  UNIT: in TIME := ns);
end TEXTIO;
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
注释(Notes)
使用Textio包,要使用library和use语句。
In order to use any of the declarations of the Textio package, the
library and use clauses have to be used.
Std_logic_1164 Package
std_logic_1164定义在库IEEE中。不是VHDL LRM的一部分。
Package std_logic_1164 is defnied in the library IEEE. This package is not part of the VHDL LRM.
说明(Description)
包std_logic_1164用来描述数字逻辑值。包含std_logic(单位)和std_logic_vector(数组)的定义。同时也包含许多VHDL函数,如解决三态冲突的函数,逻辑运算符,转换函数。
The Std_logic_1164 package is the IEEE standard for describing digital logic values in VHDL (IEEE STD 1164). It contains definitions for std_logic (single bit) and for std_logic_vector (array). It also contains VHDL functions for these types to resolve tri-state conflics, functions to define logical operators and conversion functions to and from other standard types.
package std_logic_1164 is
  type std_ulogic is ('u',  -- uninitialized
                      'x',  -- forcing  unknown
                      '0',  -- forcing  0
                      '1',  -- forcing  1
                      'z',  -- high impedance
                      'w',  -- weak unknown
                      'l',  -- weak 0
                      'h',  -- weak 1
                      '-'   -- don't care
  type std_ulogic_vector is array ( natural range <> ) of std_ulogic;
  function resolved ( s : std_ulogic_vector ) return std_ulogic;
  subtype std_logic is resolved std_ulogic;
  type std_logic_vector is array ( natural range <> ) of std_logic;
  subtype x01     is resolved std_ulogic range 'x' to '1'; -- ('x','0','1')
  subtype x01z    is resolved std_ulogic range 'x' to 'z'; -- ('x','0','1','z')
  subtype ux01    is resolved std_ulogic range 'u' to '1'; -- ('u','x','0','1')
  subtype ux01z   is resolved std_ulogic range 'u' to 'z'; -- ('u','x','0','1','z')
  function "and"  ( l : std_ulogic; r : std_ulogic ) return ux01;
  function "nand" ( l : std_ulogic; r : std_ulogic ) return ux01;
  function "or"   ( l : std_ulogic; r : std_ulogic ) return ux01;
  function "nor"  ( l : std_ulogic; r : std_ulogic ) return ux01;
  function "xor"  ( l : std_ulogic; r : std_ulogic ) return ux01;
  function "xnor" ( l : std_ulogic; r : std_ulogic ) return ux01;
  function "not"  ( l : std_ulogic                 ) return ux01;
  function "and"  ( l, r : std_logic_vector  ) return std_logic_vector;
  function "and"  ( l, r : std_ulogic_vector ) return std_ulogic_vector;
  function "nand" ( l, r : std_logic_vector  ) return std_logic_vector;
  function "nand" ( l, r : std_ulogic_vector ) return std_ulogic_vector;
  function "or"   ( l, r : std_logic_vector  ) return std_logic_vector;
  function "or"   ( l, r : std_ulogic_vector ) return std_ulogic_vector;
  function "nor"  ( l, r : std_logic_vector  ) return std_logic_vector;
  function "nor"  ( l, r : std_ulogic_vector ) return std_ulogic_vector;
  function "xor"  ( l, r : std_logic_vector  ) return std_logic_vector;
  function "xor"  ( l, r : std_ulogic_vector ) return std_ulogic_vector;
  function "xnor" ( l, r : std_logic_vector  ) return std_logic_vector;
  function "xnor" ( l, r : std_ulogic_vector ) return std_ulogic_vector;
  function "not"  ( l : std_logic_vector  ) return std_logic_vector;
  function "not"  ( l : std_ulogic_vector ) return std_ulogic_vector;
  function to_bit       ( s : std_ulogic;        xmap : bit := '0') return bit;
  function to_bitvector ( s : std_logic_vector ; xmap : bit := '0') return bit_vector;
  function to_bitvector ( s : std_ulogic_vector; xmap : bit := '0') return bit_vector;
  function to_stdulogic       ( b : bit               ) return std_ulogic;
  function to_stdlogicvector  ( b : bit_vector        ) return std_logic_vector;
  function to_stdlogicvector  ( s : std_ulogic_vector ) return std_logic_vector;
  function to_stdulogicvector ( b : bit_vector        ) return std_ulogic_vector;
  function to_stdulogicvector ( s : std_logic_vector  ) return std_ulogic_vector;
  function to_x01  ( s : std_logic_vector  ) return  std_logic_vector;
  function to_x01  ( s : std_ulogic_vector ) return  std_ulogic_vector;
  function to_x01  ( s : std_ulogic        ) return  x01;
  function to_x01  ( b : bit_vector        ) return  std_logic_vector;
  function to_x01  ( b : bit_vector        ) return  std_ulogic_vector;
  function to_x01  ( b : bit               ) return  x01;
  function to_x01z ( s : std_logic_vector  ) return  std_logic_vector;
  function to_x01z ( s : std_ulogic_vector ) return  std_ulogic_vector;
  function to_x01z ( s : std_ulogic        ) return  x01z;
  function to_x01z ( b : bit_vector        ) return  std_logic_vector;
  function to_x01z ( b : bit_vector        ) return  std_ulogic_vector;
  function to_x01z ( b : bit               ) return  x01z;
  function to_ux01  ( s : std_logic_vector  ) return  std_logic_vector;
  function to_ux01  ( s : std_ulogic_vector ) return  std_ulogic_vector;
  function to_ux01  ( s : std_ulogic        ) return  ux01;
  function to_ux01  ( b : bit_vector        ) return  std_logic_vector;
  function to_ux01  ( b : bit_vector        ) return  std_ulogic_vector;
  function to_ux01  ( b : bit               ) return  ux01;
  function rising_edge  (signal s : std_ulogic) return boolean;
  function falling_edge (signal s : std_ulogic) return boolean;
  function is_x ( s : std_ulogic_vector ) return  boolean;
  function is_x ( s : std_logic_vector  ) return  boolean;
  function is_x ( s : std_ulogic        ) return  boolean;
end std_logic_1164;
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
Numeric_Std Package
The package numeric_std is defnied in the library IEEE. This package is not part of the VHDL LRM.
说明(Description)
IEEE Standard 1076.3 (the numeric standard) was developed to help synthesis tool users and vendors by providing standard, portable data types and operations for numeric data, and by providing more clearly defined meaning for the nine values of the IEEE 1164 std_logic and std_ulogic data types. It defines the package numeric_std.
Two new numeric data types are declared in the numeric_std package:
type unsigned is array (natural range <>) of std_logic;
type signed is array (natural range <>) of std_logic;
1
2
Unsigned represents unsigned integer data, signed represents signed integer data in two’s complement form. In signed and unsigned arrays, the leftmost bit is treated as the most significant bit.
Corresponding arithmetic operations and functions are defined in the package for the two data types.
zhangyukun 发表于 2019-2-16 09:21:33 | 显示全部楼层
库语句(Library)
大鹏 发表于 2019-2-16 10:00:54 | 显示全部楼层
VHDL中库语句
GMT+8, 2026-5-22 17:22 , Processed in 0.032076 second(s), 20 queries .
