查看: 4171|回复: 5
怎样在一个进程里面判断不同时钟信号的上升沿
lilanjun004 发表于 2011-5-19 09:56:13 | 显示全部楼层 |阅读模式
如题:要在同一个进程里面判断两个时钟信号的上升沿,编译报错如下:
Error (10822): HDL error at deal_voice48.vhd(70): couldn't implement registers for assignments on this clock edge
进程中是要检测CLKIN和CLKOUT的上升沿,process中的敏感信号只添加了CLKIN
honhu 发表于 2011-7-8 20:41:32 | 显示全部楼层
把“CLKIN”和“CLKOUT”同时加到process里
蓝余 发表于 2011-7-11 22:18:57 | 显示全部楼层
感觉问题不是很明确。
562023030 发表于 2011-7-13 14:01:01 | 显示全部楼层
process(valid,valid_reg,prog_full,prog_full_reg)
        if (valid = '1' and valid_reg = '0') then
            wr_en <= '1';
        elsif (prog_full = '1' and prog_full_reg = '0') then
            wr_en <= '0';
        end if;
        start_fft <= (not prog_full_reg) and prog_full ;
    end process;
562023030 发表于 2011-7-13 14:02:10 | 显示全部楼层
上面的valid_reg,prog_full_reg是valid,prog_full延迟一个周期的信号,就像这样
    process(sysclk)
        if (rising_edge(sysclk)) then
            valid_reg    <= valid;
            prog_full_reg <= prog_full;
        end if;
    end process;
562023030 发表于 2011-7-13 14:02:15 | 显示全部楼层
    process(sysclk)
            valid_reg    <= valid;
        end if;
    end process;
GMT+8, 2026-5-23 22:53 , Processed in 0.068902 second(s), 25 queries .
