查看: 1225|回复: 0
请大神帮帮忙~~急急急
Jacky1464355697 发表于 2011-5-19 10:38:16 | 显示全部楼层 |阅读模式
以下面程序为主程序,添加校园定时打铃功能,可以同时随意设定多个打铃时间
Library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsugned.all;
entity Clock is
  port( mode,set,clr,clk:in std_logic;seg7,segctrut std_logic_vector(7 downto 0));
end entity;
ARCHITECTURE arch OF Clock IS
Type st is(s0,s1,s2,s3);
signal state: st;
signal Hour, Min,Sec: integer range 0 to 59;
signal BCDH,BCDM,BCDS:std_logec_vector(7 downto 0);
signal segDat:std_logic_vector(3 downto 0);
signal blink:std_logic_vector(2 downto0);
signal blink_clk:std_logic;
signal set_reg:std_logic;
component BCD
  Port(DataIn :in integer range 0 to 59;
BCDOut ut std_logic_vector(7 downto 0)
end component;
BEGIN
Process(mode,clr)
if(clr=’1’) then
  state<=s0;
if(mode’event and mode=’1’)then
  case state is
       when s0=>state<=s1;
       when s1=>state<=s2;
       when s2=>state<=s3;
       when s3=>state<=s0;
  end case;
end if;
  end if;
end process;
process(clk)
variable blink_cnt: std_logic_vectot(7 downto 0);--(13 downto 0);
if (clr=’1’) then
  blink_clk<=’0’;
  blink_cnt:=(others =>’0’);
   if(clk’event and clk=’1’) then
     if (blink_cnt=”01100011”) then
      blink_cnt:=(others=>’0’) ;
      blink_clk<=not blink_clk;
      blink_cnt:=blink_cnt+1;
     end if;
end if;
   end if;
end process;
process(state,blink_clk)
   case state is
      when s0=>blink<=”000”;
  when s1=>blink<=(2=>blink_clk, others=>’0’);
  when s2=>blink<=(1=>blink_clk, others=>’0’);
  when s3=>blink<=(0=>blink_clk, others=>’0’);
end case;
   end process;
process(clk,state,clr)
variable clk_cnt:std_logic_vector(9 downto 0);
   if(clr=’1’) then
     Hour<=0;Min<=0;Sec<=0;
     clk_cnt:=(others =>’0’);set_reg<=’0’;
     case state is
     when s0=>
          if (clk_cnt=”1111100111”) then
            clk_cnt:=(others=>’0’);
            if (Sec=59) then
              Sec<=0;
              If(Min=59) then
                Min<=0;
                 If(Hour=23) then
                   Hour<=0;
                 else Hour<=Hour+1;
                  end if;
            else Min<=Min+1;
             end if;
          else Sec<=sec+1;
            end if;
         else clk_cnt:=clk_cnt+1;
           end if;
      when s1=>
           if(set=’1’) then
             if set_reg=’0’ then set_reg<=’1’;
                  if (Hour=23) then Hour<=0;
                   else Hour<=Hour+1;
                   end if;
                 end if;
               else set_reg<=’0’;
                end if;
       when s2=>
           if(set=’1’) then
                  if (Min=59) then
Min<=0;
                   else Min<=+1;
                   end if;
                 end if;
               else set_reg<=’0’;
                end if;
      when s3=>
           if(set=’1’) then
                  if (Sec=23) then
Sec<=0;
                   else Sec<=Sec+1;
                   end if;
                 end if;
               else set_reg<=’0’;
                end if;
             end case;
           end if;
          end if;
   end process;
HBCD:BCD
   port map(Hour,BCDH);
HBCD:BCD
   port map(Min,BCDM);
HBCD:BCD
   port map(Sec,BCDS);
process(clk,clr)
variable cnt:std_logic_vector(2downto 0);
   if(clr=’1’) then
     cnt:= (others =>’0’);
     segCtr<=(others =>’0’);
     cnt:=cnt+1;
     case cnt is
         when”000” =>
           segDat<=BCDH(7 downto 4) or (blink(2)&blin(2)&blink(2)&blink(2));
           segctr<=”10000000”;
         when”001” =>
           segDat<=BCDH(3 downto 0) or (blink(2)&blin(2)&blink(2)&blink(2));
           segctr<=”01000000”;
          when”010” =>
           segDat<=”1010”;
           segctr<=”00100000”;
         when”011” =>
           segDat<=BCDM(7 downto 4) or (blink(1)&blin(1)&blink(1)&blink(1));
           segctr<=”00010000”;
         when”100” =>
           segDat<=BCDM(3 downto 0) or (blink(1)&blin(1)&blink(1)&blink(1));
           segctr<=”00001000”;
         when”101” =>
           segDat<=”1010”
           segctr<=”00000100”;
         when”110” =>
           segDat<=BCDS(7 downto 4) or (blink(0)&blin(0)&blink(0)&blink(0));
           segctr<=”00000010”;
         when”111” =>
           segDat<=BCDS(3 downto 0) or (blink(0)&blin(0)&blink(0)&blink(0));
           segctr<=”00000001”;
            end case;
          end if;
       end if ;
  end process;
process(segDat)
  case segDat is
    when ”0000” => seg7<=”11111100”;
when ”0001” => seg7<=”01100000”;
when ”0010” => seg7<=”11011010”;
when ”0011” => seg7<=”11110010”;
when ”0100” => seg7<=”01100110”;
when ”0101” => seg7<=”10110110”;
when ”0110” => seg7<=”10111110”;
when ”0111” => seg7<=”11100000”;
when ”1000” => seg7<=”11111110”;
when ”1001” => seg7<=”11110110”;
when ”1010” => seg7<=”00000010”;
when others => seg7<=”00000000”;
  end case;
end process;
end arch;
本人QQ1464355697   有酬谢
GMT+8, 2026-5-24 00:55 , Processed in 0.041477 second(s), 20 queries .
