查看: 2044|回复: 2
求助 帮忙解决warning问题
Spacebottle 发表于 2011-5-24 17:05:21 | 显示全部楼层 |阅读模式
WARNING:Xst:1710 - FF/Latch  <idex_signimm_8> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_7> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_6> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_5> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_4> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_3> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_2> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_1> (without init value) has a constant value of 0 in block <mips/stage_ex>.
WARNING:Xst:1710 - FF/Latch  <idex_signimm_0> (without init value) has a constant value of 0 in block <mips/stage_ex>.
是什么情况啊
请各位前辈指教
 楼主| Spacebottle 发表于 2011-5-24 17:09:28 | 显示全部楼层
源代码:
reg [31:0] idex_signimm;
always @(posedge clk) begin
       idex_signimm    <= id_signimm;
伯尼 发表于 2011-5-24 18:16:22 | 显示全部楼层
                                 -FF 锁存器 <idex_signimm_8>(没有初始值)有一个恒定值为0的块<mips/stage_ex>.
GMT+8, 2026-5-24 01:11 , Processed in 0.032066 second(s), 21 queries .
