查看: 1815|回复: 2
求VHDL达人帮忙翻译
如风自在 发表于 2011-5-24 20:33:17 | 显示全部楼层 |阅读模式
-- 8 registers of 16 bits each
  seldreg_s <= w & seldreg;
  process (clk,reset)
        if reset='1' then
            axreg_s <= (others => '0');
            cxreg_s <= (others => '0');
            dxreg_s <= (others => '0');
            bxreg_s <= (others => '0');
            spreg_s <= (others => '0');
            bpreg_s <= (others => '0');
            sireg_s <= (others => '0');
            direg_s <= (others => '0');
        elsif rising_edge(clk) then
            if (wrd='1') then
                case seldreg_s is
                    when "0000" => axreg_s(7 downto 0)  <= dibus(7 downto 0);     -- w=0 8 bits write
                    when "0001" => cxreg_s(7 downto 0)  <= dibus(7 downto 0);
                    when "0010" => dxreg_s(7 downto 0)  <= dibus(7 downto 0);
                    when "0011" => bxreg_s(7 downto 0)  <= dibus(7 downto 0);
                    when "0100" => axreg_s(15 downto 8) <= dibus(7 downto 0);
                    when "0101" => cxreg_s(15 downto 8) <= dibus(7 downto 0);
                    when "0110" => dxreg_s(15 downto 8) <= dibus(7 downto 0);
                    when "0111" => bxreg_s(15 downto 8) <= dibus(7 downto 0);
                    when "1000" => axreg_s <= dibus;      -- w=1 16 bits write
                    when "1001" => cxreg_s <= dibus;
                    when "1010" => dxreg_s <= dibus;
                    when "1011" => bxreg_s <= dibus;
                    when "1100" => spreg_s <= dibus;
                    when "1101" => bpreg_s <= dibus;
                    when "1110" => sireg_s <= dibus;
                    when others => direg_s <= dibus;
                end case;
            end if;
        end if;
    end process;
由于是初学VHDL,要做毕业设计。以上这段看不太懂,是什么意思?是赋值么?
emaklutz 发表于 2011-5-26 09:43:26 | 显示全部楼层
在不同的状态,将DIBUS的DATA赋值给不同的寄存器
honhu 发表于 2011-7-8 20:34:56 | 显示全部楼层
代码中  "reset " 起到异步清零的作用,"wrd"  是同布置数的功能。哪那个为1,就执行哪个。
GMT+8, 2026-5-23 22:13 , Processed in 0.058503 second(s), 21 queries .
