查看: 1458|回复: 0
这是一个消抖模块~里面dff有两个输出~这该怎么改?求助
chenhaoyumax 发表于 2011-5-27 10:33:59 | 显示全部楼层 |阅读模式
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_arith.ALL;
USE IEEE.std_logic_signed.ALL;
ENTITY key_sync IS
       PORT (key_in     :  IN   std_logic;
             clk        :  IN   std_logic;
             key_out    :  OUT  std_logic);
END key_sync;
ARCHITECTURE Behavioral OF key_sync IS
             COMPONENT dff
                  PORT (clk   :  IN   std_logic;
                        d     :  IN   std_logic;
                        q     :  OUT  std_logic;
                        qn    :  OUT  std_logic);
             END COMPONENT dff;
             SIGNAL tmp1 :  std_logic;
             SIGNAL tmp2 :  std_logic;
             SIGNAL tmp3 :  std_logic;
             SIGNAL tmp4 :  std_logic;
             SIGNAL tmp5 :  std_logic;
             SIGNAL tmp6 :  std_logic;
BEGIN
        tmp2 <= key_in NAND tmp1;
        tmp1 <= tmp3 NAND tmp2;
        key_out <= tmp4 AND tmp5;
        U1: dff
          PORT MAP(clk,tmp2,tmp4,tmp3);
        U2: dff
          PORT MAP(clk,tmp4,tmp6,tmp5);
END Behavioral;
GMT+8, 2026-5-23 23:04 , Processed in 0.037423 second(s), 20 queries .
