查看: 1885|回复: 0
500强美资IT公司招聘LTE芯片PHY DSP|FPGA开发|架构工程师
I2C 发表于 2011-5-28 07:04:05 | 显示全部楼层 |阅读模式
工作地点:北京
岗位职责:
Senior LTE PHY layer design engineer
Beijing
Responsibilities
In this position, as a senior LTE PHY layer design engineer in Company China Research Center,
- You will be responsible for LTE PHY layer design on Company processor.
- Contribute to spec and high level and detail design documentation
Qualifications
You should possess at least a bachelor degree in electrical engineering or computer science with at least 3-4 years of experience on wireless PHY layer design
Must have:
- Experienced on wireless PHY layer processing and design based on DSP, or FPGA, or other processors.
- The ability to independently design signal processing algorithm and C coding according to the high level design document.
- In-depth understanding of LTE PHY processing procedure such as BS procedure for transmit and receive, random access, downlink and uplink control channel procedure
- In-depth understanding of LTE PHY protocol and algorithms, such as OFDM, MIMO, channel coding, channel estimation etc.
- Strong C/C programming skill on DSP or embedded processor or Company processor.
- Experience and ability to work independently and in a team environment
- Strong documentation ability, and good verbal communication and/or technical writing skills in both Chinese and English
- Strong problem solving capability, self-motivated and work under pressure.
Preference:
- C/C programming on Linux is a plus.
- Fundamental understanding of Company® Architecture Processors Chipsets, embedded design experience on Company CPU is a plus
Senior LTE PHY layer architect
Beijing
Responsibilities
In this position, as a LTE PHY layer design architect in Company China Research Center.
- You will be responsible for LTE PHY layer architecture design on Company processor.
- Responsible architecture, specification, and high level design documentation
- Responsible for performance analysis, and lead PHY team to design efficient wireless algorithms on Company processor for base station
Qualifications
You should possess at least a bachelor degree in electrical engineering or computer science with at least 5-6 years of experience on wireless PHY layer design and architect experience
Must have:
- The ability for PHY layer architecture, specification, and high level design
- Performance analysis capability
- PHY software function partition and module interface design.
Preference:
招聘要求:
最低薪水:
15-25W
联系方式:
www.elitehunt.com
lanaliu@elitehunt.com/elitehunt@163.com
GMT+8, 2026-5-24 04:58 , Processed in 0.041250 second(s), 19 queries .
