查看: 3689|回复: 7
求VHDL的流水灯程序!!!!!!
thg_fly 发表于 2011-5-28 15:21:19 | 显示全部楼层 |阅读模式
求VHDL的流水灯程序!!!!!!
fpgaw 发表于 2011-5-31 08:32:13 | 显示全部楼层
跑马灯?
porereading 发表于 2011-6-2 21:18:45 | 显示全部楼层
邮箱?   qq:956693281
栗子 发表于 2011-7-18 09:56:39 | 显示全部楼层
--流水灯
--a1,a2,a3,a4,a5,a6,a7,a8代表8个灯
--控制8个灯的循环点亮,q1对时钟的上升沿计数 ,q1的变化对应8个灯的状态
library ieee;
use ieee.std_logic_1164.all;
--use ieee.std_logic_signed.all;
--use ieee.std_logic_arith.all;
entity lxd is
port (
      --reset: in std_logic;--系统复位信号
          clk:in std_logic; --1hz时钟信号
         a1,a2,a3,a4,a5,a6,a7,a8: out std_logic);
end lxd;
architecture bhv of lxd is
signal q: std_logic ;
signal q1: std_logic_vector(3 downto 0);
signal c: std_logic_vector(7 downto 0);
signal clk1: std_logic;
process(clk)  --对系统时钟3000000分频;
   variable cnt:integer range 0 to 30000000 ;
   variable q: std_logic;
if clk'event and clk='1'then
  if cnt =29999999 then
  cnt:=0 ; q:='1';
    cnt:=cnt+1; q:='0';
  end if;
end  if;
clk1<=q;
end process;
process(clk)   --------控制灯显示,q1对时钟的上升沿计数
  if q1 ="1111" then q1<="0000";
  else q1<=q1+1;
end if;
end if;
end process;
process(q1)
case q1 is
when "0000" =>c<="01111111";
when "0001" =>c<="10111111";
when "0010" =>c<="11011111";
when "0011" =>c<="11101111";
when "0100" =>c<="11110111";
when "0101" =>c<="11111011";
when "0110" =>c<="11111101";
when "0111" =>c<="11111110";
when "1000" =>c<="11111110";
when "1001" =>c<="11111101";
when "1010" =>c<="11111011";
when "1011" =>c<="11110111";
when "1100" =>c<="11101111";
when "1101" =>c<="11011111";
when "1110" =>c<="10111111";
when "1111" =>c<="01111111";
when others =>c<="11111111";
end case;
a1<=c(0);a2<=c(1);a3<=c(2);a4<=c(3);a5<=c(4);a6<=c(5);a7<=c(6);a8<=c(7);
end process;
end bhv;
蓝余 发表于 2011-7-18 11:43:11 | 显示全部楼层
楼上回帖很给力!
liujilei311 发表于 2011-7-18 15:24:06 | 显示全部楼层
的确很给力哦!!!!!
liujilei311 发表于 2011-7-18 15:24:07 | 显示全部楼层
的确很给力哦!!!!!
xiaoxiaohe 发表于 2011-9-18 14:28:22 | 显示全部楼层
很好,4楼的回答
GMT+8, 2026-5-23 20:35 , Processed in 0.033039 second(s), 21 queries .
