查看: 2586|回复: 0
在FPGA中是以何种形式实现VHDL的变量类型的?
CPLD 发表于 2010-5-3 07:13:24 | 显示全部楼层 |阅读模式
答:There is no definite answer to this.  It depends on how you write your codes.  A variable in vhdl may be synthesized into a physical net,  or it may not exist at all in the resulting circuit. 文:没有明确的答案. 它取决于所编写的代码. Vhdl中的变量可能同步到物理网络中, 或者根本不可能存在于结果电路中. )
GMT+8, 2026-5-24 07:54 , Processed in 0.030928 second(s), 19 queries .
