查看: 1470|回复: 1
vga显示的verilog程序
fpga_feixiang 发表于 2019-4-26 15:09:00 | 显示全部楼层 |阅读模式
module VGA_color_line (clk, rst_n, hs_vga, vs_vga, r_vga, g_vga, b_vga);
11
12     input clk, rst_n;  //系统时钟和低电平复位
13     output hs_vga, vs_vga;  //行同步hs_vga,场同步vs_vga
14     output r_vga, g_vga , b_vga;  //像素三基色输出R、G、B
15     reg [2:0] rgb_vga;  //相当于输入信号了
16     wire clk_vga;  //像素时钟 1688 * 1066 * 60 MZ (工业标准 108 MHZ)
17
18 // VGA_1280_1024_60fps_50MHz
19 // Horizontal Parameter( Pixel )
20     parameter
21         H_DISP  = 11'd1280,
22         H_FRONT = 11'd48,
23         H_SYNC  = 11'd112,
24         H_BACK  = 11'd248,
25         H_TOTAL = 11'd1688,
26 // Virtical Parameter( Line )
27         V_DISP  = 11'd1024,
28         V_FRONT = 11'd1,
29         V_SYNC  = 11'd3,
30         V_BACK  = 11'd38,
31         V_TOTAL = 11'd1066;
32
33 //调用IP核ALTPLL,像素频率108 MHZ
34     pll_pixel_clock    pll_pixel_clock_inst (
35         .inclk0 ( clk ),
36         .c0 ( clk_vga )   //例化端口必须是网线型
37         );
38
39 //行同步计数器(信号发生器)
40     reg [10:0] hcnt;
41     reg hs_vga;
42     always @ (posedge clk_vga or negedge rst_n)
43         begin
44             if (!rst_n)
45                 hcnt <= 0;  //复位后计数清零
46             else
47                 begin
48                     if (hcnt < H_TOTAL - 1'b1)  //判断扫描完一行,像素区间为[0, H_TOTAL - 1'b1]
49                         hcnt <= hcnt + 1'b1;
50                     else
51                         hcnt <= 0;
52                 end
53         end
54 //行同步
55     always @ (posedge clk_vga or negedge rst_n)
56         begin
57             if (!rst_n)
58             hs_vga <= 0; //因为复位后计数器置零,而0 ~ (H_DISP - 1)区间为显示区,此处必为 0
59             else
60                 begin
61                 //像素(H_DISP + H_FRONT - 1, H_DISP + H_FRONT + H_SYNC - 1]区间同步
62                     if (hcnt >= (H_DISP + H_FRONT - 1'b1) && hcnt < (H_DISP + H_FRONT + H_SYNC - 1'b1))
63                         hs_vga <= 1;  //在同步区置1,行同步
64                     else
65                         hs_vga <= 0;
66                 end
67         end
68
69 //场同步计数器(信号发生器)
70     reg [10:0] vcnt;
71     reg vs_vga;
72     always @ (posedge clk_vga or negedge rst_n)  //异步复位
73         begin
74             if (!rst_n)
75             vcnt <= 0;  //复位后计数清零
76             else
77                 begin
78                     if (hcnt == H_DISP - 1'b1)  //判断显示区扫面完一行,此处也可判断整个一行扫描完
79                         begin
80                             if (vcnt < V_TOTAL - 1'b1)  //判断扫面完一场
81                                 vcnt <= vcnt + 1'b1;
82                             else
83                                 vcnt <= 0;
84                         end
85                     else
86                         vcnt <= vcnt;
87                 end
88         end
89 //场同步
90     always @ (posedge clk_vga or negedge rst_n)
91         begin
92             if (!rst_n)
93                 vs_vga <= 0;
94             else
95                 begin
96                     if (vcnt >= (V_DISP + V_FRONT - 1'b1) && vcnt < (V_DISP + V_FRONT + V_SYNC - 1'b1))
97                         vs_vga <= 1;
98                     else
99                         vs_vga <= 0;
100                 end
101         end
102
103 //在显示期坐标根据显示的扫描而改变,在非显示期,坐标置零
104     wire [10:0] xpos_vga, ypos_vga;
105     assign xpos_vga = (hcnt < H_DISP) ? (hcnt + 1'b1) : 11'd0;  //在显示区横坐标 + 1(即1~H_DISP)
106     assign ypos_vga = (vcnt < V_DISP) ? (vcnt + 1'b1) : 11'd0;  //在显示区竖坐标 + 1(即1~V_DISP)
107
108 //竖彩条显示
109     always @ (posedge clk_vga or negedge rst_n)
110         if (!rst_n)
111             rgb_vga <= 3'b000;
112         else
113             begin
114                 /*if (xpos_vga > 0 && xpos_vga < 80) rgb_vga <= 3'b010;
115                 else if (xpos_vga < 160) rgb_vga <= 3'b011;
116                 else if (xpos_vga < 240) rgb_vga <= 3'b100;
117                 else if (xpos_vga < 320) rgb_vga <= 3'b101;
118                 else if (xpos_vga < 400) rgb_vga <= 3'b110;
119                 else if (xpos_vga < 480) rgb_vga <= 3'b111;
120                 else if (xpos_vga < 560) rgb_vga <= 3'b001;
121                 else if (xpos_vga < 640) rgb_vga <= 3'b010;
122                 else if (xpos_vga < 720) rgb_vga <= 3'b011;
123                 else if (xpos_vga < 800) rgb_vga <= 3'b100;
124                 else if (xpos_vga < 880) rgb_vga <= 3'b101;
125                 else if (xpos_vga < 960) rgb_vga <= 3'b110;
126                 else if (xpos_vga < 1040) rgb_vga <= 3'b111;
127                 else if (xpos_vga < 1120) rgb_vga <= 3'b001;
128                 else if (xpos_vga < 1200) rgb_vga <= 3'b010;
129                 else if (xpos_vga <= 1280) rgb_vga <= 3'b011;
130                 else rgb_vga <= 3'b000;*/
131
132             if (xpos_vga > 0 && xpos_vga <= 80) rgb_vga <= 3'b111;//white
133             else if (xpos_vga > 80 && xpos_vga <= 160) rgb_vga <= 3'b100;//red
134             else if (xpos_vga > 160 && xpos_vga <= 240) rgb_vga <= 3'b101;//mangenta
135             else if (xpos_vga > 240 && xpos_vga <= 320) rgb_vga <= 3'b110;//yellow
136             else if (xpos_vga > 320 && xpos_vga <= 400) rgb_vga <= 3'b010;//green
137             else if (xpos_vga > 400 && xpos_vga <= 480) rgb_vga <= 3'b001;//blue
138             else if (xpos_vga > 480 && xpos_vga <= 560) rgb_vga <= 3'b011;//cyan
139             else if (xpos_vga > 560 && xpos_vga <= 640) rgb_vga <= 3'b000;
140
141             else if (xpos_vga > 640 && xpos_vga <= 720) rgb_vga <= 3'b111;//white
142             else if (xpos_vga > 720 && xpos_vga <= 800) rgb_vga <= 3'b100;
143             else if (xpos_vga > 800 && xpos_vga <= 880) rgb_vga <= 3'b101;
144             else if (xpos_vga > 880 && xpos_vga <= 960) rgb_vga <= 3'b110;
145             else if (xpos_vga > 960 && xpos_vga <= 1040) rgb_vga <= 3'b010;
146             else if (xpos_vga > 1040 && xpos_vga <= 1120) rgb_vga <= 3'b001;
147             else if (xpos_vga > 1120 && xpos_vga <= 1200) rgb_vga <= 3'b011;
148             else if (xpos_vga > 1200 && xpos_vga <= 1280) rgb_vga <= 3'b111;
149             else rgb_vga <= 3'b000;//black,这个很重要,不然颜色不怎么正常
150
151         end
152
153 //三基色分离(可省,直接用 rgb_vga)
154     assign r_vga = rgb_vga[2];
155     assign g_vga = rgb_vga[1];
156     assign b_vga = rgb_vga[0];
157
158 endmodule
zhangyukun 发表于 2019-4-27 09:19:47 | 显示全部楼层
vga显示的verilog程序
GMT+8, 2026-5-22 18:49 , Processed in 0.031537 second(s), 20 queries .
