查看: 2954|回复: 0
在VHDL中, 定义为SIGNAL的量起到什么作用?什么时候需要定义这个量?
CPLD 发表于 2010-5-3 07:14:19 | 显示全部楼层 |阅读模式
在VHDL中, 定义为SIGNAL的量起到什么作用?什么时候需要定义这个量?下面的程序
ARCHITECTURE EXER2_ARCH OF EXERCISE2 IS
SIGNAL TEM: STD_LOGIC;
BEGIN
TEM<=PIN50 AND PIN51;
PIN8 <=TEM;
END EXER2_ARCH;
和如下的程序有何区别?
BEGIN
PIN8<=PIN50 AND PIN51;
END EXER2_ARCH;
答:If PIN8 is declared in your port list,  the 2 examples are identical.  From a hardware design's perspective,  you can think of a vhdl "signal" as an electrical signal.  So basically you can declare every object as "signal".  >From a simulation's perspective,  there is a fundamental difference between "signal" and "variable" in vhdl.  A variable is nothing more than an object that holds a value.  A variable assignment occurs instantly in a vhdl simulation.  Also,  a variable can only exist within a process,  so it cannot transfer values across processes.  A signal,  on the other hand,  has a history of values.  Whenever a signal assignment occurs,  the vhdl simulator schedules an event to update the signal value after a certain period of simulation time - the signal does not get this new value instantly in the simulation time domain.  Also,  a signal can exists outside processes.  Sounds complicated,  but for most of the time you can simply use vhdl "signal" in your hardware design.  (参考译文:如果在端口表中声明了PIN8, 这两个示例是一样的. 从硬件设计的角度看, 可以将vhdl "signal"视为电子信号. 因此, 基本上可以将每个对象声明为“signal”. 从仿真角度看, vhdl中的"signal" 与 "variable"是根本不同的. 变量只不过是拥有值的对象. 变量分配即时出现在vhdl仿真中. 而且, 变量只能存在于一个过程内, 因此它不能通过过程来传递值. 另一方面, 信号有多个值. 不论何时分配信号, vhdl仿真都会在某个仿真时段安排一个事件来更新信号的值. 在仿真时域里, 信号不会立即获得这个新的值. 而且信号可以存在于过程之外. 听起来好象有点复杂, 但大多数时候, 在硬件设计中可以只使用vhdl "信号". )
GMT+8, 2026-5-24 07:52 , Processed in 0.031136 second(s), 22 queries .
