查看: 2549|回复: 0
IP CAPTION 就是核发生器, 它运行在核发生器目录下吗?
CPLD 发表于 2010-5-3 07:17:39 | 显示全部楼层 |阅读模式
答:I think you mean "IP Capture".  The IP Capture tool provides designers with an automated method to identify,  capture,  and document a core.  The core can exist in the form of synthesizable VHDL or Verilog code,  or a fixed function netlist.  Once the new module has been captured,  it can be installed into and distributed from a user's local copy of the Xilinx CORE Generator system.  (参考译文:所指的应该是"IP Capture"吧. IP Capture工具为设计者提供了自动识别、捕获和归档核的方法. 核可以综合VHDL或Verilog码, 或固定功能连接表的形式存在. 一旦捕获了新模块, 就能够将核装入, 并从用户的本机Xilinx CORE Generator副本中分配此核. )
Details of the IP Capture tools can be found from Xilinx website .  http://www. xilinx. com/page_moved/ipcenter_e. htm?url=/ipcenter/designreuse/ipic. htm(有关IP Capture工具的详细资料, 请访问相关网站. )
GMT+8, 2026-5-24 07:57 , Processed in 0.031423 second(s), 19 queries .
