查看: 2293|回复: 1
输入管脚带有上拉电阻, 有时还需要外加上拉电阻, 他们的作用是什么?
CPLD 发表于 2010-5-3 07:23:04 | 显示全部楼层 |阅读模式
答:The pull-up resistors built into the FPGA I/O pin are relatively weak - usually in the order of several tens of Kohm to a hundred Kohm.  It will be too slow if you rely on these weak pull-up to charge up an open-drain signal to logic '1'.  You can speed it up by adding a stronger external pull up resistor. (参考译文:置入FPGA I/O引脚的上拉电阻相对较弱, 通常为几十千欧至几百千欧. 如果依靠这些弱电阻来将开漏信号填充至逻辑“1”, 则速度会很慢. 通过添加外部上拉电阻可以提高速度. )
Sunlife 发表于 2015-4-7 11:38:04 | 显示全部楼层
上级芯片或模块和本级芯片或模块的时钟是异步时钟域的
GMT+8, 2026-5-23 10:31 , Processed in 0.047698 second(s), 20 queries .
