查看: 1618|回复: 4
自动售货机vhdl代码(转载)
zxopenljx 发表于 2019-8-7 10:51:28 | 显示全部楼层 |阅读模式
#此帖为转载贴,原地址:http://www.fpgaw.com/thread-85840-1-13.html#
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity drink_auto_sale is
         port(clk: in std_logic;
                   reset:in std_logic;
                   sw101:in std_logic;
                   sw102:in std_logic;
                   buy : out std_logic;
                   back: out std_logic);
end drink_auto_sale;
architecture Behavioral of drink_auto_sale is
type state_type is(st0,st1);
signal cs ,ns : state_type;
process(clk,reset)
         if(reset = '1') then
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160; cs <= st0;
&#160; &#160;&#160; &#160;&#160; &#160;elsif(clk'event and clk = '1') then&#160; &#160;
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160; cs <= ns;
&#160; &#160;&#160; &#160;&#160; &#160;end if;
end process;
process(reset ,cs)
&#160; &#160;&#160; &#160;&#160; &#160;case cs is
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160; when st0 =>&#160; &#160;&#160; &#160;&#160;&#160;if( sw101 = '1') then
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;ns <= st1;
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;buy<= '0';
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;back<= '0';
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;elsif(sw102 = '1') then
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;ns <= st0;
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;buy<= '1';
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;back <= '0';
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;else
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;ns <= st0 ;
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;buy <= '0';
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;end if;
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160; when st1 => if(sw101 = '1') then
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;buy <= '1';
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160;&#160;back <= '1';
&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160;&#160; &#160; when others => ns <= st0;
&#160; &#160;&#160; &#160;&#160; &#160;end&#160;&#160;case;
end process;
end Behavioral;
设 计过程:设定三个状态:0分,5分;当状态为0分时,接收到5分信号脉冲后转为5分;接收到10分信号脉冲时,转到0分状态,同时弹出饮料,不找零;状态 为5分时,接受到5分信号,弹出饮料,不找零,返回0分状态;当接受到10分状态时,弹出饮料,找零,并返回零分状态。
#  如有侵权,请联系本人删帖。谢谢#
hellokity 发表于 2019-8-7 15:33:22 | 显示全部楼层
自动售货机vhdl代码
月影星痕 发表于 2019-8-9 09:38:53 | 显示全部楼层
自动售货机vhdl代码
 楼主| zxopenljx 发表于 2023-3-21 17:45:16 | 显示全部楼层
自动售货机vhdl代码(转载)
LYF 发表于 2023-3-22 09:14:35 | 显示全部楼层
自动售货机vhdl代码(转载)
http://www.fpgaw.com/forum.php?m ... 5&fromuid=59610
(出处: 集成电路技术分享)
GMT+8, 2026-5-22 17:19 , Processed in 0.034464 second(s), 19 queries .
