查看: 1341|回复: 1
UART实验程序设计及分析
fpga_feixiang 发表于 2019-8-23 11:12:34 | 显示全部楼层 |阅读模式
UART实验程序设计及分析
UART实验程序设计及分析
void Uart_Printf(char *fmt,...)
    va_list ap;             //声明一个va_list,
    char string[256];
    va_start(ap,fmt);       //然后用va_start函数来获取参数列表中的参数
       /* 函数名: vsprintf  功能: 送格式化输出到串中
        返回值: 正常情况下返回生成字串的长度
       (除去\0),错误情况返回负值
       用 法: int vsprintf(char *string, char *format, va_list param);
       // 将param 按格式format写入字符串string中
       注: 该函数会出现内存溢出情况,
       建议使用vsnprintf   */
    vsprintf(string,fmt,ap);
    Uart_SendString(string);
    va_end(ap);           //把ap指向NULL
http://blog.sina.com.cn/s/blog_642c9bdd0100llov.html
//发送字符串由发送字符组成
void Uart_SendString(char *pt)
    while(*pt)
        Uart_SendByte(*pt++);
void Uart_SendByte(int data)
    if(whichUart==0)          //选择第几个串口
        if(data=='\n')        //当发送的是换行回车符时做的动作
            while(!(rUTRSTAT0 & 0x2));
            WrUTXH0('\r');
//等待原来的数据已经发送结束再把数据写进发送缓冲寄存器
        while(!(rUTRSTAT0 & 0x2));   //Wait until THR is empty.
        WrUTXH0(data);
其中:#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000023)=(unsigned char)(ch)
寄存器定义。
WrUTXH0('\r');就是把'\r'写到寄存器[0x50000023]里
<tbody><tr><td width="670px"><div>RdURXH0(),WrUTXH0(),找不到函数的原型,后来在寄存器定义里面看到了。如下:
<p>#define rUTXH0&nbsp;&nbsp;(*(volatile unsigned char *)0x1d00020)<br>#define rUTXH1&nbsp;&nbsp;(*(volatile unsigned char *)0x1d04020)<br>#define rURXH0&nbsp;&nbsp;(*(volatile unsigned char *)0x1d00024)<br>#define rURXH1&nbsp;&nbsp;(*(volatile unsigned char *)0x1d04024)<br>#define WrUTXH0(ch)&nbsp;(*(volatile unsigned char *)0x1d00020)=(unsigned char)(ch)<br>#define WrUTXH1(ch)&nbsp;(*(volatile unsigned char *)0x1d04020)=(unsigned char)(ch)<br>#define RdURXH0()&nbsp;(*(volatile unsigned char *)0x1d00024)<br>#define RdURXH1()&nbsp;(*(volatile unsigned char *)0x1d04024)<br>#define UTXH0&nbsp;&nbsp;(0x1d00020)&nbsp;&nbsp;&nbsp; //byte_access address by BDMA<br>#define UTXH1&nbsp;&nbsp;(0x1d04020)<br>#define URXH0&nbsp;&nbsp;(0x1d00024)<br>#define URXH1&nbsp;&nbsp;(0x1d04024)</p>
<p>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; WrUTXH0('\r'),即把'\r'写到寄存器[0x1d00020]里面,而寄存器[0x50000027]是UART0的发送寄存器,也就是换行。而rUTXH0,也是UART的发送保持寄存器,若要做WrUTXH0('\r')相同的效果,则需把相应的命令值赋给rUTXH0:即:rUTXH0=&#8220;\r&#8221;。</p>
</div></td></tr></tbody></table>
http://www.360doc.com/content/11/0112/17/4591140_86020062.shtml
#define A&nbsp;&nbsp;&nbsp; (* (volatile unsigned *)&nbsp;&nbsp; 0x48000000 )</span></div>
<div><br>对于不同的计算机体系结构,设备可能是端口映射,也可能是内存映射。如果系统结构支持独立的IO地址空间,并且是端口映射,就必须使用汇编语言完成实际对设备的控制,因为C语言并没有提供真正的&#8220;端口&#8221;的概念。</div>
<div>如果是内存映射,那就方便的多了。</div>
<div>举个例子,比如向寄存器A(地址假定为0x48000000)写入数据0x01,那么就可以这样设置了:</div>
<div>#define A (*(volatile unsigned *) 0x48000000 )<br>...<br>&nbsp;&nbsp;&nbsp;&nbsp; A = 0x01;<br>...</div>
<div>这实际上就是内存映射机制的方便性了。其中volatile关键字是嵌入式系统开发的一个重要特点。</div>
<div>volatile(可变的)这个关键字说明这变量可能会被意想不到地改变,这样编译器就不会去假设这个变量的值了。这种&#8220;意想不到地改变&#8221;,不是由程序去改变,而是由硬件去改变。</div>
<div>volatile 限定编译器不对这个指针的指向的存储单元进行优化, 即不用通用寄存器暂时代替这个指针的指向的存储单元,而是每次取值都直接到指针的指向的存储单元取值.volatile 主要用于变量会异步改变的情下,主要有三个方面:</div>
<div>1.cpu外设寄存器</div>
<div>2.中断和主循环都会用到的全局变量</div>
<div>3.操作系统中的线程间都会用到的公共变量.</div>
<div>&nbsp;</div>
<div>上述表达式拆开来分析:</div>
<div>首先(volatile unsigned *) 0x48000000的意思是把0x48000000强制转换成volatile unsigned类型的指针,即对指针的操作的范围是从0x48000000开始的4个字节(int型),暂记为p。那么就有:</div>
<div>#define A&nbsp;&nbsp; *p,即A为P指针指向位置的内容了。这里就是通过内存寻址访问到寄存器A,可以读/写操作!</div>
//串口初始化设置
void Uart_Init(int pclk,int baud)
    int i;
    if(pclk == 0)
    pclk    = PCLK;
    rUFCON0 = 0x0;   //UART channel 0 FIFO control register, FIFO disable
    rUFCON1 = 0x0;   //UART channel 1 FIFO control register, FIFO disable
    rUFCON2 = 0x0;   //UART channel 2 FIFO control register, FIFO disable
    rUMCON0 = 0x0;   //UART chaneel 0 MODEM control register, AFC disable
    rUMCON1 = 0x0;   //UART chaneel 1 MODEM control register, AFC disable
//UART0
    rULCON0 = 0x3;   //Line control register : Normal,No parity,1 stop,8 bits
    rUCON0  = 0x245;   // Control register  interrupt request mode, trigger level use PCLK
    rUBRDIV0=( (int)(pclk/16/baud+0.5) -1 );   //Baud rate divisior register 0
//UART1
    rULCON1 = 0x3;
    rUCON1  = 0x245;
    rUBRDIV1=( (int)(pclk/16/baud+0.5) -1 );
//UART2
    rULCON2 = 0x3;
    rUCON2  = 0x245;
    rUBRDIV2=( (int)(pclk/16/baud+0.5) -1 );
for(i=0;i<100;i++);
同理,接收数据的程序如下:
//判断接收是否空
void Uart_TxEmpty(int ch)
    if(ch==0)
        while(!(rUTRSTAT0 & 0x4)); //Wait until tx shifter is empty.
char Uart_Getch(void)
    if(whichUart==0)
        while(!(rUTRSTAT0 & 0x1)); //Receive data ready
        return RdURXH0();
//此函数供RTC 调用,和Uart_Getch的区别在于没while的死循环
char Uart_GetKey(void)
    if(whichUart==0)
        if(rUTRSTAT0 & 0x1)    //Receive data ready
            return RdURXH0();
            return 0;
void Uart_GetString(char *string)
    char *string2 = string;
    char c;
    while((c = Uart_Getch())!='\r')
        if(c=='\b')
            if( (int)string2 < (int)string )
                Uart_Printf("\b \b");
                string--;
            *string++ = c;
            Uart_SendByte(c);
    *string='\0';
    Uart_SendByte('\n');
//把发送的字符变为数字,识别负号,
//和十六进制。还可以进一步完善   以下两个函数是处理数据
int Uart_GetIntNum(void)
    char str[30];
    char *string = str;
    int base     = 10;
    int minus    = 0;
    int result   = 0;
    int lastIndex;
    int i;
    Uart_GetString(string);
    if(string[0]=='-')
        minus = 1;
        string++;
    if(string[0]=='0' && (string[1]=='x' || string[1]=='X'))
        base    = 16;
        string += 2;
    lastIndex = strlen(string) - 1;
    if(lastIndex<0)
        return -1;
    if(string[lastIndex]=='h' || string[lastIndex]=='H' )
        base = 16;
        string[lastIndex] = 0;
        lastIndex--;
    if(base==10)
        result = atoi(string);
        result = minus ? (-1*result):result;
        for(i=0;i<=lastIndex;i++)
            if(isalpha(string))
                if(isupper(string))
                    result = (result<<4) + string - 'A' + 10;
                    result = (result<<4) + string - 'a' + 10;
                result = (result<<4) + string - '0';
    return result;
int Uart_GetIntNum_GJ(void)
    char string[16] ;
    char *p_string = string ;
    char c;
    int i = 0 ;
    int data = 0 ;
    while(   ( c = Uart_Getch()) != '\r'  )
              if(c=='\b')              p_string--;
              else         *p_string++=c;
              Uart_SendByte( c ) ;
    *p_string = '\0';
       i = 0 ;
       while( string != '\0' )
              data = data * 10 ;
              if( string<'0'||string>'9' )
                     return -1 ;
              data = data + ( string-'0' ) ;
              i++ ;
       return data ;
zxopenhl 发表于 2019-8-23 16:38:21 | 显示全部楼层
UART实验程序设计及分析
GMT+8, 2026-5-22 18:47 , Processed in 0.031662 second(s), 20 queries .
