查看: 1661|回复: 2
Pcie 协议理解
月影星痕 发表于 2019-8-28 13:44:03 | 显示全部楼层 |阅读模式
1. OBFF Mechanism  = Optimized Buffer Flush/Fill (OBFF) Mechanism
cite from: 《PCI EXPRESS BASE SPECIFICATION, REV. 3.1a 》
The Optimized Buffer Flush/Fill (OBFF) Mechanism enables a Root Complex to report to
Endpoints (throughout a hierarchy) time windows when the incremental platform power cost for
Endpoint bus mastering and/or interrupt activity is relatively low.
“OBFF” – System memory path available for Device memory read/write bus master activities
2. PRSNT 信号如何连线?
PRSNT1_N
PRSNT2_N_X1
PRSNT2_N_X4
PRSNT2_N_X8
PRSNT2_N_X16     需要学习《PCI_Express_CEM_r3.0_008152013_TS_Clean.pdf》
2. SlimSAS的这个信号作用,BP_TYPEB;
解决:
基于《SFF-8448_R1.3b.pdf》,
Vendor Specific Pins (VSP)
3.PCIE的3V3_VAUX电流大小:
来自:《PCI Express ®   Base Specification Revision 3.1a December 7, 2015 》
PCI Express ®   Card Electromechanical Specification Revision 3.0
版权声明:本文为CSDN博主「helloasimo」的原创文章,遵循CC 4.0 by-sa版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/helloasimo/article/details/92796184
zxopenljx 发表于 2019-9-1 17:24:21 | 显示全部楼层
Pcie 协议理解
zxopenljx 发表于 2023-4-4 10:14:48 | 显示全部楼层
Pcie 协议理解
GMT+8, 2026-5-22 17:16 , Processed in 0.031289 second(s), 19 queries .
