查看: 1500|回复: 2
TLC549驱动
fpga_feixiang 发表于 2019-9-16 21:12:01 | 显示全部楼层 |阅读模式
module ADC_TLC549(
                I_Clk,
                I_Rst_n,
                I_Adc_Data_In,
                O_CS_n,
                O_Adc_Clk,
                O_Adc_Data_Out,
                O_Adc_Data_Vaild
//I/O
input                        I_Clk;
input                        I_Rst_n;
input                        I_Adc_Data_In;
output                O_CS_n;
output                O_Adc_Clk;
output [7:0]        O_Adc_Data_Out;
output                O_Adc_Data_Vaild;
/*************I/O时钟计数器********************/
parameter   IO_Clk_Freq=7'd99;  //系统时钟50MHz,500k=50/100->99;
parameter   IO_Clk_Freq_div=7'd49;//采样时钟频率的两倍,对应与采样时钟上升沿
parameter   IO_Clk_Width=3'd7;
reg        [IO_Clk_Width-1:0] R_IO_Clk_Count;
reg                           R_Clk_En;
always @ (posedge I_Clk)
        if (~I_Rst_n)
          R_IO_Clk_Count<=7'b0;
          if (R_Clk_En)
               if (R_IO_Clk_Count==IO_Clk_Freq)
                  R_IO_Clk_Count<=R_IO_Clk_Count+7'd1;
assign O_Adc_Clk=(R_IO_Clk_Count>IO_Clk_Freq_div)?1'b1:1'b0;
/***************转换时间计时器*********************************/
parameter                Delay_Time=9'd499;//转换时钟为4MHz,总等待时间需要超过34个周期,这里取40个周期,则为500个系统时钟
parameter                CS_n_Time=9'd449;
parameter                Transfer_Count_Width=4'd9;
reg                [Transfer_Count_Width-1:0] R_Transfer_Count;
reg                                           R_Transfer_En;
   if (~I_Rst_n)
          R_Transfer_Count<=9'b0;
          if (R_Transfer_En)
              if (R_Transfer_Count==Delay_Time)
                  R_Transfer_Count<=R_Transfer_Count;
                  R_Transfer_Count<=R_Transfer_Count+9'd1;
/**************总采样过程状态机***********************/
reg        [3:0] R_State;
reg              R_CS_n;
reg        [7:0] R_Data;
reg              R_Vaild;
        if (~I_Rst_n)
          R_State<=4'b0;
          R_CS_n<=1'b1;
          R_Data<=8'b0;
          R_Transfer_En<=1'b0;
          R_Clk_En<=1'b0;
          R_Vaild<=1'b0;
          case (R_State)
          4'd0:
                  R_Vaild<=1'b0;
                  R_Transfer_En<=1'b1;
                  R_Clk_En<=1'b0;
                  R_CS_n<=1'b1;
                  if (R_Transfer_Count==CS_n_Time)
                   R_State<=R_State+4'd1;
                   R_State<=R_State;
                4'd1:
                   R_CS_n<=1'b0;
                          R_State<=R_State;
                 4'd2,4'd3,4'd4,4'd5,4'd6,4'd7,4'd8,4'd9:
                   R_Clk_En<=1'b1;
                        if (R_IO_Clk_Count==IO_Clk_Freq_div)
                          R_Data<={R_Data[6:0],I_Adc_Data_In};
                          R_State<=R_State;
                 4'd10:
                          R_Clk_En<=1'b0;
                          R_State<=4'd0;
                          R_Vaild<=1'b1;
                          R_CS_n<=1'b1;
                          R_Clk_En<=1'b1;
                          R_State<=R_State;
                          R_Vaild<=1'b0;
                          R_CS_n<=1'b0;
          default:
                    R_State<=4'b0;
               R_CS_n<=1'b1;
               R_Data<=8'b0;
               R_Clk_En<=1'b0;
               R_Vaild<=1'b0;
          endcase
assign        O_CS_n=R_CS_n;
assign        O_Adc_Data_Out=R_Data;
assign        O_Adc_Data_Vaild=R_Vaild;
zxopenljx 发表于 2019-9-17 09:58:32 | 显示全部楼层
感谢楼主分享
Sunlife 发表于 2019-9-17 14:03:57 | 显示全部楼层
GMT+8, 2026-5-22 16:35 , Processed in 0.031487 second(s), 20 queries .
