查看: 1617|回复: 0
SDRAM刷新状态机设计程序——仅供参考
fpga_feixiang 发表于 2019-11-26 17:51:17 | 显示全部楼层 |阅读模式
        模块名称 : AUTO REFRESH(自动刷新模块)非背靠背刷新
        模块说明 : tRP(min)=15ns  tRFC(min)=66ns
        --2015-10-06
`include "sdram_head.v"
module sdr_ref_fsm(sys_clk, rst_n, ref_done, ref_bus);
        input sys_clk;
        input rst_n;                           //刷新模块启动信号
        output reg ref_done;  //刷新完成标志信号
        output reg [19:0] ref_bus;
        localparam s0 = 2'b00;
        localparam s1 = 2'b01;
        localparam s2 = 2'b10;
        reg [2:0] count;  //延时计数器
        reg [1:0] state;
        always @ (posedge sys_clk)
                if (!rst_n)
                                ref_bus[19:16] <= `NOP;  //cs_ras_cas_we_cke_ba_a
                                ref_bus[15] <= 1;
                                ref_bus[14:0] <= 0;
                                ref_done <= 0;
                                count <= 3'd0;
                                state <= s0;
                        case (state)
                                s0 :  begin
                                                        ref_bus[19:16] <= `PRECHANGE; //置位后立刻发送预充电命令
                                                        ref_bus[10] <= 1;                                   //选择所有bank
                                                        state <= s1;
                                s1 :         begin         //从S1到S2已经经过了一拍,所以这里`tRP-1
                                                        if (count < `tRP-1)
        count <= count + 1'b1;
        count <= 0;
        state <= s2;
        ref_bus[19:16] <= `REFRESH;   //发送自动刷新命令
                                s2 :         begin
                                                        if(count < `tRFC-1)
        ref_done <= 1;        //刷新过程全部完成,输出标志信号
                                default : ref_bus[19:16] <= `NOP;
                        endcase
GMT+8, 2026-5-22 18:49 , Processed in 0.031557 second(s), 20 queries .
