查看: 1447|回复: 1
SDRAM页写状态机设计程序——仅供参考
fpga_feixiang 发表于 2019-11-26 17:54:02 | 显示全部楼层 |阅读模式
        模块名称 : SDRAM写模块
        模块说明 : 当有写事件发生时:1.发送激活命令、行地址、bank地址
        2.经过tRCD之后,发送写命令、列地址、写数据、a[10]拉高标志自动刷新
        3.继续发送第二个数据(BL=2)
        --2015-10-08
module sdr_write(wr_rst_n, sys_clk, int_addr, wr_done, wr_bus, int_dq, out_en, local_wdata, wr_data_ok);
        input sys_clk;
        input wr_rst_n;
        input [24:0] int_addr;
        input [15:0] local_wdata;
        output reg wr_done;
        output reg [19:0] wr_bus;
        output reg [15:0] int_dq;
        output reg out_en;
        output reg wr_data_ok;
        localparam s0 = 3'b000;
        localparam s1 = 3'b001;
        localparam s2 = 3'b010;
        localparam s3 = 3'b011;
        localparam s4 = 3'b100;
        localparam s5 = 3'b101;
        reg [2:0] state;
        reg [9:0] count;
        always @ (posedge sys_clk)
                if (!wr_rst_n)
                                wr_bus[19:16] <= `NOP;
                                wr_bus[15] <= 1;
                                wr_bus[14:0] <= 0;
                                int_dq <= 0;
                                count <= 0;
                                out_en <= 0;
                                wr_done <=0;
                                state <= s0;
                                wr_data_ok <= 0;
                        case (state)
                                s0 :        begin
                                                        wr_bus[19:16] <= `ACT;                           //发送激活命令
                                                        wr_bus[14:13] <= int_addr[24:23]; //发送bank地址
                                                        wr_bus[12:0] <= int_addr[22:10];  //发送行地址
                                                        state <= s1;
                                                        wr_data_ok <= 1;
                                s1 :  if (count < `tRCD-1)  //`tRCD-1 = 1
        count <= count + 1'b1;
        wr_bus[19:16] <= `WR;
        wr_bus[10] <= 1;                          //拉高a[10],自动刷新
        wr_bus[9:0] <= int_addr[9:0]; //列地址
        int_dq <= local_wdata;
        out_en <= 1;
        count <= 0;
        state <= s2;
                                s2 :                begin
        if (count < `WR_SIZE)
        out_en <= 1;
        else if(count == `WR_SIZE)
        out_en <= 1;
        wr_data_ok <= 0;
        out_en <= 1;
        count <= 0;
        state <= s3;
                                s3 : begin
                                                out_en <= 0;
                                                wr_bus[19:16] <= `BT;  //发出突发终止命令
                                                state <= s4;
                                s4 : begin
                                                if (count < 2)
        count <= 0;
        wr_bus[19:16] <= `PRECHANGE;
        wr_bus[10] <= 1;
        state <= s5;
                                s5 :  if (count < 2)
        wr_done <= 1;
                                default : wr_bus[19:16] <= `NOP;
                                endcase
zhangyukun 发表于 2019-11-26 19:33:24 | 显示全部楼层
GMT+8, 2026-5-22 16:35 , Processed in 0.042137 second(s), 20 queries .
