查看: 2767|回复: 3
标志信号跨越两个时钟处理方法
20080067 发表于 2010-5-3 11:00:06 | 显示全部楼层 |阅读模式
标志信号跨越两个时钟处理方法
A flag to another clock domainIf the signal that needs to cross the clock domains is just a pulse (i.e. it lasts just one clock cycle), we call it a "flag". The previous design usually doesn't work (the flag might be missed, or be seen for too long, depending on the ratio of the clocks used).
We still want to use a synchronizer, but one that works for flags.
The trick is to transform the flags into level changes, and then use the two flip-flops technique.
module Flag_CrossDomain(    clkA, FlagIn_clkA,     clkB, FlagOut_clkB);// clkA domain signalsinput clkA, FlagIn_clkA;// clkB domain signalsinput clkB;output FlagOut_clkB;reg FlagToggle_clkA;reg [2:0] SyncA_clkB;// this changes level when a flag is seenalways @(posedge clkA) if(FlagIn_clkA) FlagToggle_clkA <= ~FlagToggle_clkA;// which can then be sync-ed to clkBalways @(posedge clkB) SyncA_clkB <= {SyncA_clkB[1:0], FlagToggle_clkA};// and recreate the flag from the level changeassign FlagOut_clkB = (SyncA_clkB[2] ^ SyncA_clkB[1]);endmoduleNow if you want the clkA domain to receive an acknowledgment (that clkB received the flag), add a busy signal.
module FlagAck_CrossDomain(    clkA, FlagIn_clkA, Busy_clkA,     clkB, FlagOut_clkB);// clkA domain signalsinput clkA, FlagIn_clkA;output Busy_clkA;// clkB domain signalsinput clkB;output FlagOut_clkB;reg FlagToggle_clkA;reg [2:0] SyncA_clkB;reg [1:0] SyncB_clkA;always @(posedge clkA) if(FlagIn_clkA & ~Busy_clkA) FlagToggle_clkA <= ~FlagToggle_clkA;always @(posedge clkB) SyncA_clkB <= {SyncA_clkB[1:0], FlagToggle_clkA};always @(posedge clkA) SyncB_clkA <= {SyncB_clkA[0], SyncA_clkB[2]};assign FlagOut_clkB = (SyncA_clkB[2] ^ SyncA_clkB[1]);assign Busy_clkA = FlagToggle_clkA ^ SyncB_clkA[1];endmodule
zxopenljx 发表于 2020-4-11 14:06:16 | 显示全部楼层
标志信号跨越两个时钟处理方法
zxopenljx 发表于 2023-8-11 16:52:41 | 显示全部楼层
标志信号跨越两个时钟处理方法
zxopenljx 发表于 2023-8-11 16:53:00 | 显示全部楼层
标志信号跨越两个时钟处理方法
GMT+8, 2026-5-22 15:03 , Processed in 0.032709 second(s), 21 queries .
