查看: 5059|回复: 9
电子时钟VHDL程序与仿真
zxopenyz 发表于 2020-1-20 08:36:09 | 显示全部楼层 |阅读模式
1. 10进制计数器设计
10进制计数器VHDL程序
--文件名:counter10.vhd。
--功能:10进制计数器,有进位C
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity counter10 is
    Port ( clk : in std_logic;
          reset : in std_logic;
          din : in std_logic_vector(3 downto 0);
          dout : out std_logic_vector(3 downto 0);
                  c: out std_logic);
end counter10;
architecture Behavioral of counter10 is
   signal count : std_logic_vector(3 downto 0);
    dout <= count;
        process(clk,reset,din)
           if reset='0'then
                 count <= din ;
                 c<='0';
       elsif rising_edge(clk) then
                   if count = "1001" then
                           count <= "0000";
                           c<='1';
                           count <= count+1;
                           c<='0';
           end if;
      end if;
    end process;
end Behavioral;
 楼主| zxopenyz 发表于 2020-1-20 08:36:44 | 显示全部楼层
2. 6进制计数器设计
6进制计数器VHDL程序
--文件名:counter6.vhd。
--功能:6进制计数器,有进位C
library IEEE;
entity counter6 is
         din : in std_logic_vector(2 downto 0);
         dout : out std_logic_vector(2 downto 0);
                 c: out std_logic);
end counter6;
architecture Behavioral of counter6 is
signal count : std_logic_vector(2 downto 0);
    dout <= count;
           if reset= '0' then
                  count <= din;
                  c<='0';
                   if count="101" then
                           count<="000";
                           c<='1';
                           count<=count+1;
                           c<='0';
          end if;
      end if;
   end process;
end Behavioral;
 楼主| zxopenyz 发表于 2020-1-20 08:37:20 | 显示全部楼层
3. 6进制计数器设计
24进制计数器VHDL程序
--文件名:counter24.vhd。
--功能:24进制计数器。
library IEEE;
entity counter24 is
         din : in std_logic_vector(5 downto 0);
         dout : out std_logic_vector(5 downto 0));
end counter24;
architecture Behavioral of counter24 is
signal count : std_logic_vector(5 downto 0);
    dout <= count;
           if reset= '0' then
                   count <= din;
                   if count(3 downto 0)="1001" then
                         count(3 downto 0)<="0000";
                        count(5 downto 4)<=count(5 downto 4) +1;
                        count(3 downto 0)<=count(3 downto 0)+1;
         end if;
                 if count="100011" then
                   count<="000000";
         end if;
      end if;
   end process;
end Behavioral;
 楼主| zxopenyz 发表于 2020-1-20 08:37:50 | 显示全部楼层
4. 译码器设计
--文件名:decoder.vhd。
--功能:将4bit二进制数译码,在LED上显示相应数字。
library IEEE;
entity decoder is
Port (din:in std_logic_vector(3 downto 0 );   --四位二进制码输入
dout: out std_logic_vector(6 downto 0) );  --输出LED七段码
end decoder;
architecture Behavioral of decoder is
process(din)
case din is
when "0000" => dout<="0000001";--0
when "0001" => dout<="1001111";--1
when "0010" => dout<="0010010";--2
when "0011" => dout<="0000110";--3
when "0100" => dout<="1001100"; --4
when "0101" => dout<="0100100";--5
when "0110" => dout<="0100000";--6
when "0111" => dout<="0001111";--7
when "1000" => dout<="0000000";--8
when "1001" => dout<="0000100";--9
when others => dout<="1111111";
end case;
end process;
end Behavioral;
 楼主| zxopenyz 发表于 2020-1-20 08:38:37 | 显示全部楼层
5. 顶层设计
顶层设计VHDL程序
--文件名:clock.vhd。
--功能:时钟的顶层设计。
library IEEE;
entity clock is
    Port ( clk : in std_logic;                 --1Hz
         reset : in std_logic;                --复位信号
         dins : in std_logic_vector(6 downto 0);--秒钟预置
         dinm : in std_logic_vector(6 downto 0);--分钟预置
         dinh : in std_logic_vector(5 downto 0);--时钟预置
                 secondl: out std_logic_vector(6 downto 0);--秒钟低位输出
                 secondh: out std_logic_vector(6 downto 0); --秒钟高位输出
                 minutel: out std_logic_vector(6 downto 0); --分钟低位输出
                 minuteh: out std_logic_vector(6 downto 0); --分钟高位输出
                 hourl: out std_logic_vector(6 downto 0); --小时低位输出
                 hourh: out std_logic_vector(6 downto 0)); --小时高位输出
end clock;
architecture Behavioral of clock is
   component counter10 is
                 c: out std_logic);
end component;
        component counter6 is
                 c: out std_logic);
        end component;
        component counter24 is
        end component;
        component decoder is
         dout: out std_logic_vector(6 downto 0));
        end component;
        signal c1,c2,c3,c4:std_logic;
        signal doutsl,doutml:std_logic_vector(3 downto 0);
        signal doutsh,doutmh:std_logic_vector(2 downto 0);
        signal douth:std_logic_vector(5 downto 0);
        signal rdoutsh,rdoutmh:std_logic_vector(3 downto 0);
        signal rdouth:std_logic_vector(7 downto 0);
        rdoutsh <= '0'&doutsh;   --将秒钟高位数据变为4位,再进行译码
        rdoutmh <= '0'&doutmh;  --将分钟高位数据变为4位,再进行译码
        rdouth <="00"&douth;   --将时钟高位数据变为4位,再进行译码
        u1: counter10 port map( clk=>clk,reset=>reset,
                            din=>dins(3 downto 0),
                                                dout=>doutsl,
                                                c=>c1);
   u2: counter6 port map( clk=>c1,reset=>reset,
                          din=>dins(6 downto 4),
                                          dout=>doutsh,
                                          c=>c2);
   u3: counter10 port map(        clk=>c2,reset=>reset,
                            din=>dinm(3 downto 0),
                                                dout=>doutml,
                                                c=>c3);
   u4: counter6 port map( clk=>c3,reset=>reset,
                               din=>dinm(6 downto 4),
                                                   dout=>doutmh,
                                                   c=>c4);
        u5: counter24 port map( clk=>c4,reset=>reset,
                               din=>dinh,
        dout=>douth);
    u6: decoder port map( din => doutsl,dout => secondl);         --秒的低位
        u7: decoder port map( din => rdoutsh,dout => secondh); --秒的高位
        u8: decoder port map( din => doutml,dout => minutel);  --分的低位
        u9: decoder port map( din => rdoutmh,dout => minuteh); --分的高位
        u10: decoder port map( din => rdouth(3 downto 0),dout => hourh);--时的低位
        u11: decoder port map( din => rdouth(7 downto 4),dout => hourl);--时的高位
end Behavioral;
月影星痕 发表于 2020-1-20 08:48:28 | 显示全部楼层
电子时钟VHDL程序与仿真
dameihuaxia 发表于 2020-2-9 17:19:27 | 显示全部楼层
电子时钟VHDL程序与仿真
月影星痕 发表于 2020-3-1 19:21:33 | 显示全部楼层
电子时钟VHDL程序与仿真
zxopenljx 发表于 2023-7-24 17:43:06 | 显示全部楼层
电子时钟VHDL程序与仿真
GMT+8, 2026-5-22 12:03 , Processed in 0.219723 second(s), 22 queries .
