查看: 1683|回复: 3
TLC549的驱动代码
fpga_feixiang 发表于 2020-3-2 12:34:56 | 显示全部楼层 |阅读模式
module TLC549 (
                    input clk,
                    input reset,
                    input AD_DATA,
                    output AD_CS,
                    output AD_CLK,
                    output clk_display,
                    output reg [7:0] readdata
// clk=50MHz , AD_CLK_r = 1MHz
reg  AD_CLK_r;
reg[5:0] DCLK_DIV;
always @(posedge clk or negedge reset)
  if(!reset)
      DCLK_DIV <= 1'b0;
      AD_CLK_r <= 1'b0;
  else if(DCLK_DIV < 6'd50) DCLK_DIV <= DCLK_DIV+1'b1;
      DCLK_DIV <= 0;
      AD_CLK_r <= ~AD_CLK_r;
assign clk_display = AD_CLK_r;
reg[4:0] COUNTER;
always @(posedge AD_CLK_r or negedge reset)
    if(!reset) COUNTER <= 1'b0;
    else COUNTER <= COUNTER+1'b1;
assign AD_CS = (COUNTER <= 5'd9)? 1'b0 : 1'b1;
assign AD_CLK =  (COUNTER >= 5'd2 && COUNTER <= 5'd9)? AD_CLK_r : 1'b0;
reg[7:0] data_reg;
always @(negedge AD_CLK_r)
  if(COUNTER >= 5'd2 && COUNTER <= 5'd9)
       data_reg[0] <= AD_DATA;
       data_reg[7:1] <= data_reg[6:0];
  else  readdata <= data_reg;
4、数码管显示代码:
module display(
                input clk,
                input[7:0] data,
                input reset,
                output reg [7:0] seg,
                output reg [3:0] com );
reg [14:0] cnt;
always@(posedge clk or negedge reset)
   if(!reset) cnt <= 12'd0;
   else cnt <= cnt + 1'b1;
reg[7:0] seg_reg;
always@(cnt[11:10] or data)
  case(cnt[11:10])
   2'b00 : begin com <= 4'b1110; seg_reg <= data%8'd10;      end
   2'b01 : begin com <= 4'b1101; seg_reg <= data%8'd100/8'd10;  end
   2'b10 : begin com <= 4'b1011; seg_reg <= data/8'd100;     end
   default : begin com <= 4'b1111;seg_reg <= 8'bzzzz_zzzz;end
  endcase
always @(com or seg_reg)
case(seg_reg[3:0])
  4'h0:seg=8'hc0; //显示0
  4'h1:seg=8'hf9; //显示1
  4'h2:seg=8'ha4; //显示2
  4'h3:seg=8'hb0; //显示3
  4'h4:seg=8'h99; //显示4
  4'h5:seg=8'h92; //显示5
  4'h6:seg=8'h82; //显示6
  4'h7:seg=8'hf8; //显示7
  4'h8:seg=8'h80; //显示8
  4'h9:seg=8'h90; //显示9
      default: seg=8'hff;
endcase
大鹏 发表于 2020-3-15 09:51:50 | 显示全部楼层
TLC549的驱动代码
大鹏 发表于 2020-3-19 09:55:23 | 显示全部楼层
TLC549的驱动代码
GMT+8, 2026-5-22 18:48 , Processed in 0.033777 second(s), 23 queries .
