查看: 1094|回复: 1
FPGA 使用verilog 编写的AD tlc549 测试程序,数码管做显示
fpga_feixiang 发表于 2020-3-2 12:36:13 | 显示全部楼层 |阅读模式
**author : fengdawei
**data   : 2014/10/6
**description :
模块number_mod_module U5、smg_encoder_module U6、smg_scan_module U7、
row_scan_module U1、column_scan_module U2参照黑金数码管显示代码,用于显示
AD转换后的三位数值;
模块smg_check U4用于测试数码管正常显示;
模块ad_tlc549 U3用于AD处理,返回一个八位的数据,时序图具体参考TI官方资料
**此测试程序是为将ad数据存储到RAM和从RAM读走,测试ip核做准备。
module experiment_ram(
clk,
rst,
//enable_ad,
ad_data,
row_scan_sig,
column_scan_sig,
ad_cs,
ad_clk
input clk;
input rst;
//input enable_ad;
input ad_data;
output [7:0] row_scan_sig;
output [2:0] column_scan_sig;
output ad_cs;
output ad_clk;
wire [7:0] smg_display_data;
ad_tlc549 U3
.clk(clk),
.rst(rst),
//.enable_ad(enable_ad),
.ad_data(ad_data),
.ad_cs(ad_cs),
.ad_clk(ad_clk),
.digit_data(smg_display_data)
//smg_check模块用于测试数码管
smg_check U4
.clk(clk),
.rst(rst),
.smg_display_data(smg_display_data)
wire [3:0] hundred_data;
wire [3:0] ten_data;
wire [3:0] one_data;
.clk(clk),
.rst(rst),
.number_data(smg_display_data),
.hundred_data(hundred_data),
.ten_data(ten_data),
.one_data(one_data)
wire [7:0] hundred_smg_data;
wire [7:0] ten_smg_data;
wire [7:0] one_smg_data;
.clk(clk),
.rst(rst),
.one_data(one_data),
.hundred_smg_data(hundred_smg_data),
.ten_smg_data(ten_smg_data),
.one_smg_data(one_smg_data)
smg_scan_module U7
.clk(clk),
.rst(rst),
.ten_smg_data(ten_smg_data),//8'b1100_0000
.one_smg_data(one_smg_data),//8'b1100_0000
.row_scan_sig(row_scan_sig),
.column_scan_sig(column_scan_sig)
***The maximum I/O CLOCK input frequency of the TLC548 is 2.048 MHz,
and the I/O CLOCK input frequency of theTLC549 is specified up to 1.1 MHz.
***the TLC548 and TLC549 provide an on-chip system clock that operates typically at 4 MHz
and requires no external components.
***Conversion Time...17 μs Max
***NOTES: A. The conversion cycle, which requires 36 internal system clock periods (17 μs maximum),
is initiated with the eighth I/O clock pulse trailing edge after CS  goes low for the
channel whose address exists in memory at the time.
B. The most significant bit (A7) is automatically placed on the DATA OUT bus after CS is
brought low. The remaining seven bits (A6–A0) are clocked out on the first seven I/O
clock falling edges. B7–B0 follows in the same manner.
**40 000 conversions per second for the TLC549
module ad_tlc549(
clk,
rst,
//enable_ad,
ad_data,
ad_cs,
ad_clk,
digit_data
input clk;
input rst;
//input enable_ad;
input ad_data;
output ad_cs;
output ad_clk;
output [7:0]digit_data;
//2^(11)=2048
reg [10:0] clk_cnt;
always @ (posedge clk or negedge rst)
if(!rst)
clk_cnt<=11'd0;
else if(clk_cnt>=11'd1320)
clk_cnt<=11'b0;
clk_cnt<=clk_cnt+1'b1;
系统板50MHZ->一个时钟周期为0.02us
cs_high_data_exchange 17us->850个clk脉冲
每秒转换40000次,每次需要每次转换时间间隔25us,采样间隔 必须在25us以上
cs_low_data_read 1.4us+8个1MHZ的脉冲->1.4us+8us=9.4us ->70+400=470个clk脉冲
total clk pulse=1320个时钟周期
wire cs_high_data_exchange;
wire cs_low_data_read;
reg rcs;
assign cs_high_data_exchange=(clk_cnt>=11'd0) &#160;&&(clk_cnt<11'd850);
assign cs_low_data_read &#160; =(clk_cnt>=11'd850)&&(clk_cnt<11'd1320);
assign cs_low_data_read1 &#160; =(clk_cnt>=11'd920)&&(clk_cnt<11'd1320);
if(!rst)
rcs<=1'b1;
if(cs_high_data_exchange)
rcs<=1'b1;
rcs<=1'b0;
assign ad_cs=rcs;
//2^6=64
//将系统时钟50MHz进行50分频成1MHz
reg [5:0] div_cnt;
reg rad_clk;
reg [3:0] count_read_data_pulse;
if(!rst)
div_cnt<=6'd0;
rad_clk<=1'b0;
count_read_data_pulse<=4'd0;
else if((cs_low_data_read1 )&&(count_read_data_pulse<8))
div_cnt<=div_cnt+1'b1;
if(div_cnt<25)
rad_clk<=1'b1;
else if(div_cnt>=49)
count_read_data_pulse<=count_read_data_pulse+1'b1;
div_cnt<=6'd0;
rad_clk<=1'b0;
else if(!cs_low_data_read1)
rad_clk<=1'b0;
rad_clk<=1'b0;
assign ad_clk=rad_clk;
reg [7:0] rad_data;
if(!rst)
rad_data<=8'd0;
case (clk_cnt)
11'd920 :rad_data[7] <= ad_data;
11'd970 :rad_data[6] <= ad_data;
11'd1020:rad_data[5] <= ad_data;
11'd1070:rad_data[4] <= ad_data;
11'd1120:rad_data[3] <= ad_data;
11'd1170:rad_data[2] <= ad_data;
11'd1220:rad_data[1] <= ad_data;
11'd1270:rad_data[0] <= ad_data;
default:;
endcase
assign digit_data=rad_data;
module smg_check(
clk,
rst,
smg_display_data
input clk;
input rst;
output [7:0] smg_display_data;
//50MHz晶振:50000000为1s,10000000为0.2s
//parameter TIMES=26'd50000000;
parameter TIMES=24'd10000000;
reg [25:0] clk_cnt;
if(!rst)
clk_cnt<=26'd0;
else if(clk_cnt>TIMES)
clk_cnt<=26'd0;
reg [7:0] rsmg_display_data;
if(!rst)
rsmg_display_data<=8'd0;
else if(rsmg_display_data>8'd255)
else if(clk_cnt==TIMES)
rsmg_display_data<=rsmg_display_data+1'b1;
assign smg_display_data=rsmg_display_data;
module number_mod_module(
clk,
rst,
number_data,
hundred_data,
ten_data,
one_data
input clk;
input rst;
input [7:0] number_data;
output [3:0] hundred_data;
output [3:0] ten_data;
output [3:0] one_data;
reg [31:0] rhundred_data;
reg [31:0] rten_data;
reg [31:0] rone_data;
if(!rst)
rhundred_data<=32'd0;
rten_data<=32'd0;
rone_data<=32'd0;
else&#160;
rhundred_data<=number_data/100;
rten_data<=number_data%100/10;
rone_data<=number_data%10;
assign hundred_data=rhundred_data[3:0];
assign ten_data=rten_data[3:0];
assign one_data=rone_data[3:0];
module smg_encoder_module(
clk,
rst,
hundred_data,
ten_data,
one_data,
hundred_smg_data,
ten_smg_data,
one_smg_data
input clk;
input rst;
input [3:0] hundred_data;
input [3:0] ten_data;
input [3:0] one_data;
output [7:0] hundred_smg_data;
output [7:0] ten_smg_data;
output [7:0] one_smg_data;
parameter _0 = 8'b1100_0000, _1 = 8'b1111_1001, _2 = 8'b1010_0100,&#160;
&#160; &#160; &#160; &#160; _3 = 8'b1011_0000, _4 = 8'b1001_1001, _5 = 8'b1001_0010,&#160;
_6 = 8'b1000_0010, _7 = 8'b1111_1000, _8 = 8'b1000_0000,
_9 = 8'b1001_0000;
reg [7:0] rhundred_smg_data;
if(!rst)
rhundred_smg_data<=8'b1111_1111;
case(hundred_data)
4'd0:rhundred_smg_data<=_0;
4'd1:rhundred_smg_data<=_1;
4'd2:rhundred_smg_data<=_2;
4'd3:rhundred_smg_data<=_3;
4'd4:rhundred_smg_data<=_4;
4'd5:rhundred_smg_data<=_5;
4'd6:rhundred_smg_data<=_6;
4'd7:rhundred_smg_data<=_7;
4'd8:rhundred_smg_data<=_8;
4'd9:rhundred_smg_data<=_9;
endcase
reg [7:0] rten_smg_data;
if(!rst)
rten_smg_data<=8'b1111_1111;
case(ten_data)
4'd0:rten_smg_data<=_0;
4'd1:rten_smg_data<=_1;
4'd2:rten_smg_data<=_2;
4'd3:rten_smg_data<=_3;
4'd4:rten_smg_data<=_4;
4'd5:rten_smg_data<=_5;
4'd6:rten_smg_data<=_6;
4'd7:rten_smg_data<=_7;
4'd8:rten_smg_data<=_8;
4'd9:rten_smg_data<=_9;
endcase
reg [7:0] rone_smg_data;
if(!rst)
rone_smg_data<=8'b1111_1111;
else&#160;
case(one_data)
4'd0:rone_smg_data<=_0;
4'd1:rone_smg_data<=_1;
4'd2:rone_smg_data<=_2;
4'd3:rone_smg_data<=_3;
4'd4:rone_smg_data<=_4;
4'd5:rone_smg_data<=_5;
4'd6:rone_smg_data<=_6;
4'd7:rone_smg_data<=_7;
4'd8:rone_smg_data<=_8;
4'd9:rone_smg_data<=_9;
endcase
assign hundred_smg_data=rhundred_smg_data;
assign ten_smg_data=rten_smg_data;
assign one_smg_data=rone_smg_data;
module smg_scan_module(
clk,
rst,
hundred_smg_data,
ten_smg_data,
one_smg_data,
row_scan_sig,
column_scan_sig
input clk;
input rst;
input [7:0] hundred_smg_data;
input [7:0] ten_smg_data;
input [7:0] one_smg_data;
output [7:0] row_scan_sig; //行 --段选
output [2:0] column_scan_sig; //列 --位选
row_scan_module U1
.clk(clk),
.rst(rst),
.clk(clk),
.rst(rst),
module row_scan_module(
clk,
rst,
hundred_smg_data,
ten_smg_data,
one_smg_data,
row_scan_sig
input clk;
input rst;
parameter TIMES=18'd199_999;
reg [17:0] count;
if(!rst)
count<=18'd0;
else if(count==TIMES)
count<=18'd0;
count<=count+1'b1;
reg [1:0] t;
if(!rst)
t<=2'd0;
else if(t==2'd3)
t<=2'd0;
t<=t+1'b1;
reg [7:0] rdata;
if(!rst)
rdata<=8'd0;
case(t)
2'd0:rdata<=hundred_smg_data;
2'd1:rdata<=ten_smg_data;
2'd2:rdata<=one_smg_data;
default:;
endcase
assign row_scan_sig=rdata;
module column_scan_module(
clk,
rst,
column_scan_sig
input clk;
input rst;
reg [17:0] count;
if(!rst)
count<=18'd0;
count<=18'd0;
count<=count+1'b1;
reg [1:0] t;
if(!rst)
t<=2'd0;
else if(t==2'd3)
t<=2'd0;
t<=t+1'b1;
reg [2:0] rcolumn_scan_sig;
if(!rst)
rcolumn_scan_sig<=2'b10;
case(t)
2'd0:rcolumn_scan_sig<=3'b011;
2'd1:rcolumn_scan_sig<=3'b101;
2'd2:rcolumn_scan_sig<=3'b110;
default:;
endcase
assign column_scan_sig=rcolumn_scan_sig;
GMT+8, 2026-5-22 15:43 , Processed in 0.031733 second(s), 22 queries .
