查看: 1443|回复: 0
帮助下
hhq520189 发表于 2011-7-22 22:33:32 | 显示全部楼层 |阅读模式
有这个图(见附件),用matlab里的simulink自动生成的verilog代码如下:
//  Module: mm
//  Simulink Path: mm
//  Created: 2011-07-22 22:00:29
//  Hierarchy Level: 0
`timescale 1 ns / 1 ns
module mm
           clk,
           reset,
           clk_enable,
           In1,
           ce_out,
           Out1
  input   clk;
  input   reset;
  input   clk_enable;
  input   [63:0] In1;  // double
  output  ce_out;
  output  [63:0] Out1;  // double
  wire enb;
  reg In1_1;  // double
  reg Unit_Delay_out1;  // double
  assign enb = clk_enable;
  assign ce_out = enb;
  always @* In1_1 <= $bitstoreal(In1);
  always @ (posedge clk or posedge reset)
    begin: Unit_Delay_process
      if (reset == 1'b1) begin
        Unit_Delay_out1 <= 0.0000000000000000E+000;
      else begin
        if (enb == 1'b1) begin
          Unit_Delay_out1 <= In1_1;
    end // Unit_Delay_process
  assign Out1 = $realtobits(Unit_Delay_out1);
endmodule  // mm
但在编译时,它说:always @* In1_1 <= $bitstoreal(In1);      assign Out1 = $realtobits(Unit_Delay_out1);这两句有错误,不支持。请问下怎样把它改正确呢???谢了
GMT+8, 2026-5-23 21:28 , Processed in 0.042376 second(s), 21 queries .
