查看: 1622|回复: 4
FPGA仿真,无波形,求助!!
lihuailiang 发表于 2020-5-23 17:15:56 | 显示全部楼层 |阅读模式
1.代码
module FSM_Welcome(
        clk,
        rst_n,
        data,
        start,
        num
        input clk;
        input rst_n;
        input [7:0]data;
        input start;          //使能信号
        output reg [2:0]num;  //需要检测的序列出现的次数
        reg [3:0]state;
        localparam
                check_W = 4'd1,         //检测W
                check_e0 = 4'd2,       //检测第一个e
                check_l = 4'd3,         //检测l
                check_c = 4'd4,         //检测c
                check_o = 4'd5,         //检测o
                check_m = 4'd6,         //检测m
                check_e1 = 4'd7;       //检测第二个e
        always@(posedge clk or negedge rst_n)
        if(!rst_n)
                        state <= check_W;
                        num <= 3'd0;
        else if(start)
                        case(state)
                                check_W:        begin
                                                if(data == "W")
                                                        state <= check_e0;
                                                        state <= check_W;
                                check_e0: begin
                                                if(data == "e")
                                                        state <= check_l;
                                                else if(state == "W")
                                                        state <= check_e0;
                                                        state <= check_W;
                                check_l: begin
                                                if(data == "l")
                                                        state <= check_c;
                                                        state <= check_e0;
                                                        state <= check_W;
                                check_c: begin
                                                if(data == "c")
                                                        state <= check_o;
                                                        state <= check_e0;
                                                        state <= check_W;
                                check_o: begin
                                                if(data == "o")
                                                        state <= check_m;
                                                        state <= check_e0;
                                                        state <= check_W;
                                check_m: begin
                                                if(data == "m")
                                                        state <= check_e1;
                                                        state <= check_e0;
                                                        state <= check_W;
                                check_e1: begin
                                                if(data == "e")
        state <= check_W;
        num <= num + 1'd1;
                                                        state <= check_e0;
                                                        state <= check_W;
                                default: state <= check_W;
                        endcase
2.测试文件
`timescale 1ns/1ns
`define clk_period 20
module FSM_Welcome_tb;
        reg clk;
        reg rst_n;
   wire [7:0]data;
        reg start;
        wire [2:0]num;
        //wire flag;
        wire [511:0]data_tmp;
        reg [511:0]data_reg;
        assign data_tmp = "abcdeWelcomehijkWelcomedcba";
        if(!rst_n)
                data_reg <= 0;
        else if(start)
                data_reg <= data_reg << 8;
                data_reg <= data_tmp;
        assign data = data_reg[511:504];
FSM_Welcome FSM_Welcome(.clk(clk),.rst_n(rst_n),.data(data),.start(start),.num(num));
        initial clk = 1;
        always#(`clk_period/2)clk = ~clk;
        initial begin
                rst_n = 0;
                start = 0;
                #(`clk_period*20)
                rst_n = 1;
                #(`clk_period*10)
                start = 1;
                #(`clk_period*64)
                #200;
                $stop;
3.无波形输出
竹林风234 发表于 2020-5-23 22:51:34 | 显示全部楼层
你那个状态机的跳转不对,有几个检测的是state
 楼主| lihuailiang 发表于 2020-5-27 19:12:22 | 显示全部楼层
我已研究成功。出仿真波形了!
GMT+8, 2026-5-22 16:35 , Processed in 0.033989 second(s), 25 queries .
