查看: 1562|回复: 2
中值滤波C代码
fpga_feixiang 发表于 2020-5-27 23:16:32 | 显示全部楼层 |阅读模式
/求九个数的中值
uchar Median(uchar n1, uchar n2, uchar n3, uchar n4, uchar n5,
        uchar n6, uchar n7, uchar n8, uchar n9) {
        uchar arr[9];
        arr[0] = n1;
        arr[1] = n2;
        arr[2] = n3;
        arr[3] = n4;
        arr[4] = n5;
        arr[5] = n6;
        arr[6] = n7;
        arr[7] = n8;
        arr[8] = n9;
        for (int gap = 9 / 2; gap > 0; gap /= 2)//希尔排序
                for (int i = gap; i < 9; ++i)
                        for (int j = i - gap; j >= 0 && arr[j] > arr[j + gap]; j -= gap)
                                swap(arr[j], arr[j + gap]);
        return arr[4];//返回中值
//图像椒盐化
void salt(Mat &image, int num) {
        if (!image.data) return;//防止传入空图
        int i, j;
        srand(time(NULL));
        for (int x = 0; x < num; ++x) {
                i = rand() % image.rows;
                j = rand() % image.cols;
                image.at<Vec3b>(i, j)[0] = 255;
                image.at<Vec3b>(i, j)[1] = 255;
                image.at<Vec3b>(i, j)[2] = 255;
//中值滤波函数
void MedianFlitering(const Mat &src, Mat &dst) {
        if (!src.data)return;
        Mat _dst(src.size(), src.type());
        for(int i=0;i<src.rows;++i)
                for (int j=0; j < src.cols; ++j) {
                        if ((i - 1) > 0 && (i + 1) < src.rows && (j - 1) > 0 && (j + 1) < src.cols) {
                                _dst.at<Vec3b>(i, j)[0] = Median(src.at<Vec3b>(i, j)[0], src.at<Vec3b>(i + 1, j + 1)[0],
                                        src.at<Vec3b>(i + 1, j)[0], src.at<Vec3b>(i, j + 1)[0], src.at<Vec3b>(i + 1, j - 1)[0],
                                        src.at<Vec3b>(i - 1, j + 1)[0], src.at<Vec3b>(i - 1, j)[0], src.at<Vec3b>(i, j - 1)[0],
                                        src.at<Vec3b>(i - 1, j - 1)[0]);
                                _dst.at<Vec3b>(i, j)[1] = Median(src.at<Vec3b>(i, j)[1], src.at<Vec3b>(i + 1, j + 1)[1],
                                        src.at<Vec3b>(i + 1, j)[1], src.at<Vec3b>(i, j + 1)[1], src.at<Vec3b>(i + 1, j - 1)[1],
                                        src.at<Vec3b>(i - 1, j + 1)[1], src.at<Vec3b>(i - 1, j)[1], src.at<Vec3b>(i, j - 1)[1],
                                        src.at<Vec3b>(i - 1, j - 1)[1]);
                                _dst.at<Vec3b>(i, j)[2] = Median(src.at<Vec3b>(i, j)[2], src.at<Vec3b>(i + 1, j + 1)[2],
                                        src.at<Vec3b>(i + 1, j)[2], src.at<Vec3b>(i, j + 1)[2], src.at<Vec3b>(i + 1, j - 1)[2],
                                        src.at<Vec3b>(i - 1, j + 1)[2], src.at<Vec3b>(i - 1, j)[2], src.at<Vec3b>(i, j - 1)[2],
                                        src.at<Vec3b>(i - 1, j - 1)[2]);
                                _dst.at<Vec3b>(i, j) = src.at<Vec3b>(i, j);
        _dst.copyTo(dst);//拷贝
void main() {
        Mat image = imread("路飞.jpg");
        Mat Salt_Image;
        image.copyTo(Salt_Image);
        salt(Salt_Image, 3000);
        Mat image3, image4;
        MedianFlitering(Salt_Image, image3);
        medianBlur(Salt_Image, image4, 3);
        imshow("自定义中值滤波处理后", image3);
        imshow("openCV自带的中值滤波", image4);
        waitKey();
大鹏 发表于 2020-5-28 16:39:07 | 显示全部楼层
中值滤波C代码
GMT+8, 2026-5-22 16:36 , Processed in 0.049767 second(s), 23 queries .
