查看: 2581|回复: 0
fifo问题急需求解
闪电 发表于 2011-7-28 10:52:52 | 显示全部楼层 |阅读模式
自己写了个fifo程序!写入数据的速度快于读出数据的速度!我想将流水灯的数据写入fifo(速度快),然后每一秒读出一个数据,但是现象却不对,开始的时候流水灯正常,一个一个的亮,但是一会就不行了,就是隔一个亮一个了!不知道是怎么回事?求解!
写数据程序:
module        write_module
        clk,
        rst_n,
        full,
        led_data,
        write_en
input        clk;
input        rst_n;
input        full;
output        write_en;
output[7:0]        led_data;
reg        write_en;
always @ ( posedge clk or negedge rst_n )
        if( !rst_n ) write_en <= 1'b0;
        else if( !full ) write_en <= 1'b1;
        else write_en <= 1'b0;
reg[7:0]        led_data;
reg[3:0]        state;
                if( !rst_n ) begin
                        state <= 4'd0;
                        led_data <= 8'h00;
                else if( !full )
                        case( state )
                                4'd0:        begin  led_data <= 8'h01; state <= state + 1'b1; end
                                4'd1:        begin  led_data <= 8'h02; state <= state + 1'b1; end
                                4'd2:        begin  led_data <= 8'h04; state <= state + 1'b1; end
                                4'd3:        begin  led_data <= 8'h08; state <= state + 1'b1; end
                                4'd4:        begin  led_data <= 8'h10; state <= state + 1'b1; end
                                4'd5:        begin  led_data <= 8'h20; state <= state + 1'b1; end
                                4'd6:        begin  led_data <= 8'h40; state <= state + 1'b1; end
                                4'd7:        begin  led_data <= 8'h80; state <= 4'd0; end
                        endcase
GMT+8, 2026-5-23 20:32 , Processed in 0.032327 second(s), 23 queries .
